  1. I want to encode a mpeg2 vbr stream. The source is 352x288 (VCD PAL), but it's not a mpeg file it's RMVB.
    My question: should I encode with a VCD resolution, which is like the source resolution , or should I try 352x576 ? Will I get a sharper picture even when I try to upsize the source res?
  2. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    You're better off encoding with the same resolution as the source
  3. Member monzie's Avatar
    Nov 2003
    The Village
    As above.
    No, you will NOT get any better picture re-sizing.
    Resizing upwards works best on 'half way' (eg 512 X 384) avi's not on set standard DVD resolutions......
