I am definitely a newbee at this. Purchasing a Canopus advc 100 to transfer tapes to DVD. Is the canopus all that I will need, or do I also need a specified capture card inside the PC? I was under the asumption that the Canopus hooked between the deck and the computer and that the HD buffered the video or it went directly to the DVD burner. As you see, direction is needed. Thanks guys.
That's all you'll need to capture. It'll convert your VHS material to DV, or Digital Video.
To get it to DVD, you will need to encode and author the files.
I suggest you start reading here. You need to learn exactly what capturing, editing and authoring are. Take the time to read through the pertinent material:
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Canopus ADVC-100 and PCI Firewire card
By spiderbaby in forum Capturing and VCRReplies: 12Last Post: 5th Mar 2008, 09:39 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
