Hi all,
recently bought a Divx Player and finally reconverting my music stuff. I stumbled across this problem and still can't get out of here.
The movie is an ASF file, trying to convert it to an XVID file, but no way.
I'm posting the log of the operation (as you may see I already activated the audio inverse mapping). What can I try now to convert it? I always get an avi file with the proper audio track but with no video track...
Thanks in advance
Encoding started on Thu Dec 9 13:40:38 CET 2004
ffmpeg version 0.4.9-pre1, build 4731, Copyright (c) 2000-2004 Fabrice Bellard
configuration: --enable-mp3lame --enable-gpl --disable-vhook --enable-ffplay --disable-ffserver --enable-a52 --enable-xvid --enable-faac --enable-faad --enable-amr_nb --enable-pthreads
built on Nov 21 2004 19:41:49, gcc: 3.3 20030304 (Apple Computer, Inc. build 1666)
Input #0, asf, from '/Volumes/Excitable Disk/Movies/Music Videos/everybreath2003civera.asf':
Duration: 00:05:12.9, start: 0.000410, bitrate: 613 kb/s
Stream #0.0: Audio: wmav2, 44100 Hz, stereo, 48 kb/s
Stream #0.1: Video: wmv2, 320x240, 1.00 fps
Stream #0.2: Video: wmv2, 320x240, 1.00 fps
Stream #0.3: Video: wmv2, 320x240, 1.00 fps
Output #0, avi, to '/Volumes/Excitable Disk/Movies/Music Videos/everybreath2003civera.asf.ff.avi':
Stream #0.0: Video: xvid (hq), 320x240, 1.00 fps, q=2-9, 940 kb/s
Stream #0.1: Audio: mp3, 48000 Hz, stereo, 128 kb/s
Stream mapping:
Stream #0.1 -> #0.0
Stream #0.0 -> #0.1
Press [q] to stop encoding
[asf @ 0x376034]ff asf parser skips: 955 - 3073 o:2518 - 503 112 115 fl:555
[asf @ 0x376034]ff asf parser skiping 555b
frame= 0 q=0.0 Lsize= 5196kB time=312.5 bitrate= 136.2kbits/s
video:0kB audio:4882kB global headers:0kB muxing overhead 6.427251%
bench: utime=101.640s
Encoding completed on Thu Dec 9 13:51:07 CET 2004
Tried setting to PAL and NTSC 29.97 without luck...
EDIT: Tried now changing from XVID ffmpeg to XVID mencoder and it seems to work. At least the video track is coming through.
Thanks for your time major
hi major,
I confirm that did the trick.
encoding with xvid mencoder created the video track but not the audio track.
encoding with xvid ffmpeg created the audio track but not the video track.
what am I supposed to do to join the two? it shouldn't be a mplex I suppose...
cheers
ASF problem playing audio
By Neomorpheus in forum Software PlayingReplies: 2Last Post: 14th May 2011, 02:56 -
Problem for cut asf with H264 video
By youtpout978 in forum EditingReplies: 2Last Post: 5th Nov 2010, 08:17 -
converting asf to avi problem
By konig in forum Video ConversionReplies: 1Last Post: 6th Mar 2008, 15:37 -
Problem with recovered .asf...
By mksmri in forum Newbie / General discussionsReplies: 4Last Post: 21st Sep 2007, 11:57 -
Problem converting ASF to AVI/MP4
By yohu123 in forum Video ConversionReplies: 11Last Post: 16th Sep 2007, 12:24
