Hi,
I'm trying to use Xing encoder V2.20 to encode a 90 minute Avi to Vcd. However, Xing will only encode the first 30 seconds. I can't find a setting to bypass this, and the version I am using is registered, so I don't think it's some kind of trial limitation. Anyone know what I'm doing wrong?
I know Xing doesn't provide as high quality output as other programs (like Tmpg), but It's a lot faster, so I'm using it to make a quick file I can test splitting/burning,etc. with before I encode with Tmpg (which would take around 24 hours).
Thanks.
Xing does not have a source range filter. That's why it is a trial limitation. Probably you registered the copy in a wrong way.
Xing is a very old program and it hasnt come across some of the newer Avi files(DIVX) and i sugest you use LSX encoder and it is just as fast as XIng and it gives better quality
Thanks for the replies guys,
I re-installed Xing and it seems to be working fine now. I tried to download LSX but can't seem to find a working link anywhere.
Thanks Again
Encore converts 5.1 to stereo
By koberulz in forum Authoring (DVD)Replies: 8Last Post: 24th Oct 2011, 22:28 -
delete sound between x seconds and y seconds?
By charlieship in forum Newbie / General discussionsReplies: 3Last Post: 4th Jun 2011, 22:14 -
converts to dvd but its always to big
By dylanvega123 in forum Video ConversionReplies: 3Last Post: 5th Aug 2009, 17:53 -
WinAvi converts with No Sound
By Yanez in forum Video ConversionReplies: 5Last Post: 12th Sep 2008, 20:12 -
Gotsent..converts to where?
By macman89 in forum Video ConversionReplies: 0Last Post: 24th Jul 2008, 18:16
