I have a cd burner which i wish to keep. Having a pioneer 108 installed with the cd burner will it cause any issues? Also i have read on a website something about if your installing a dvd burner it must be on the master channel even if there is an IDE device on there.
Can't i just have it as a slave or do i need to have someone change the jumper settings from the cd burner to the dvd burner.
Any thoughts?
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 29 of 29
IMHO the DVD burner works best as a Master on the secondary IDE buss, a fact found after much messing around with several pooters. On my current PC I also have a DVD/CD combo drive on the same buss configured as the slave and that works just fine.
Artificial intelligence is no match for natural stupidity. -
Well Duchess this is what i'm thinking of doing.
1st IDE channel main HD drive as the master and the CD burner as the slave. My DVD burner as the 2nd IDE channel master and my back up HD drive as the slave.
OR
1st IDE channel main hard drive as master and the back up HD drive as slave. 2nd IDE channel DVD Burner as master CD Burner as slave.
BTW when changing channels for hard drives i dont need to format the drive? The drive was formated when being installed into the PC.
Originally Posted by Duchess -
Your first choice might be better if yo plan on ever copying CD to CD. Otherwise it won't make much of a difference. You will read a lot of stuff about combining optical and ide devices and drives operating at the slowest speed on the same channel, but I have never been able to replicate any of it. I have a similair configuration as your first choice and have no problem. I tried it all different ways and it didn't make any difference to performance. I left it that way because of the cable length. Also, all you have to do is change the little jumpers, nothing else.
Ok well I'll give my suggestion to the tech's at the store im going too.
My setup is IDE 1 Master :HD Slave:HD
IDE 2 Master :Pioneer 108 Slave : 167T DVD-Rom
I have same hookup as bodyslide, except I have no slave HD. When copying CDs or DVDs, I usually write to HD first, so this setup works well for me.
TANSTAAFL -
Originally Posted by Bodyslide
On my other computer, I've got HD and LiteOn 166S DVD-ROM on primary, and two LiteOn 52246 CD-RWs on the secondary.
I read somewhere that if you have two hard drives that they should be on the same channel - can't remember where, but no issues having it that way so who am I to questionIf in doubt, Google it. -
I didnt want to make a another post about pioneer 108. So i'll ask my question in here. When the pioneer 108 is installed and im burning data onto a dvd disc should I be worried about heat issues? I think i got one fan and its in the back of the computer tower.
One question I have is with the set up im going to do how good does my motherboard have to be to hand this? I have a Intel 850E i think well thats what it said when i download a intel chipset identify program.
Also this is the set up im going to do 1st IDE channel main HD drive as the master and the CD burner as the slave. My DVD burner as the 2nd IDE channel master and my back up HD drive as the slave.
I think i remember seeing someone or someone's mention this is a good setup. -
Sorry for another post but someone who works with computers told me i should have my set up like this.
IDE0: main HD master and backup HD slave IDE1: DVD Burner master and CDR Burner slave. -
EDIT:
Originally Posted by freestylegreekIf in doubt, Google it. -
After talking to this guy i know who fixes alot of computers and builds them i should him the site and he agree's with what bodyslide has said. The guy I know say's if you mix up the hard drives and optical drives meaning CDR, DVD. It will cause issues cause it will be looking around for it. So if you put them together meaning the setup bodyslide has it has to reason to go to one channel then to another looking for the data.
Originally Posted by Bodyslide -
Ya but do they fix computers? The guy i know does and he deals with people's issues all the time.
If you'd looked at my profile, you'd see I'm an IT Systems Officer. I look after 100 computers and while it's not a pre-requisite for "knowing my shit", you'd think I'd have a fair idea ...
Then there's my four PCs at home, not to mention the 20-odd PCs I've bought & built for family and friends that are too lazy to go to a store ...
It just seemed kinda strange that you'd go to an internet forum and hear/read the same answer 4 times, only to disregard the answers totally, but suddenly take notice as soon as one of your mates recommends the exact same thing.If in doubt, Google it. -
Sorry there i dont really look at profiles. Maybe i should start LOL.
BTW winifreid said my first choice was good. Which wasn't the one i just mentioned.
Well now im cool and know what to choose. -
If you look at the one post above, it says "If you are going to copy CD to CD", that is a good setup.
It lets you go from one IDE channel to the other, full speed.
But...If you plan to backup your DVDs, you will maturally rip, right? And if you rip and write to a drive on the same IDE channel, it has to take turns talking. IDE is "Pardon me, my turn."
HDDs on IDE 1, you rip from IDE 2 to IDE 1.Process the video, or whatever, send it back to the burners on IDE 2. No IRQ problems. Continual data transfer.
Hope this is some help, although how to set up is still going to be argued even when we get to ONE device that does it all. Then it will probably be right side up or upside down or on its side and which side.
Cheers,
George -
So your saying it should go like this?
Primary IDE Main HD (Master) Backup HD (Slave)
Seconadry IDE DVD Burner (Master) CD Burner (Slave)?
Installed latest Ripbot264, says Java is not installed, even though it is
By fatcharlie in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2011, 09:44 -
NAS newbie question - can playon be installed on it without a pc running?
By yoda313 in forum Video Streaming DownloadingReplies: 9Last Post: 12th Feb 2011, 21:46 -
Pioneer DVR-530H Question (Please help)
By Corey_Futurama in forum DVD & Blu-ray RecordersReplies: 7Last Post: 10th Jul 2010, 07:28 -
ubuntu 10.04 linux question - lost an installed package shortcut?
By aedipuss in forum ComputerReplies: 6Last Post: 18th May 2010, 17:30 -
Pioneer DVR-531H-S Question
By mattg568 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Jun 2008, 04:48
