  1. Hi,
    when I burn a CD or DVD in Nero Burning ROM, my file names always get messed up.
    e.g. If I burn the maps "ADOBE PREMIERE" and "DISCREET COMBUSTION", it becomes "ADOBEPR_" and "DISCRE_" or something like that.
    Isn't there a solution to keep the original names of the files?
    Kind regards
    canada
    Set to ascii for character set and file length to 32 and make sure you check those boxes.
    Dec 2003
    Earth
    need to bump up this dinosaur thread...
    I had the same problem too.
    using Nero OEM 6.6.0.16, I can't go into what the picture screenshot suggested, where is it?
    I tried Nero Configure - ticked Joliet filename but the problem persist.
    anyone can help?
    tks.
    Fact is stranger than Fiction
  4. Mod Neophyte redwudz's Avatar
    USA
    I have the full version of Nero 6.6.0.13 and it's just like in the picture. The OEM may not have that as an option?
    It's in both the CD and the DVD-ROM (ISO) selections under the 'ISO' tab. Other selections also, if they have a ISO tab.
