I was wondering why I would recieved a lot of macroblock, artifacts or pixelation, whatever it is call when i transcode tbe original dvd to fit a dvdr. I use deep analysis and even tried all the setting(smooth, sharp, max sharp, max smooth). I have a 12x lite-on sohw 1213s dvd burner. It comes on quite often.
Read http://www.digitalfaq.com/dvdcopy/shrink/dvdshrink.htm It should solve most of your problem.
Otherwise in one statement, I should say size does matter! -
Also, check (play) the compressed files from your hard drive and see if the same artifacts are present. Poor compatibility between your stand-alone player and your media can produce the things you are describing.
the artifacts are shown when i play it on the computer after i have transcode it. Some how my cousin, did the same thing but theirs does not produce artifcats. Could it be my computer or the burner? When i just ripped the movie into the hd with dvd decrypter it's fine. So i'm thinking its not the burner.
It may be too compressed already, the source DVDs. Are you and your cousin doing the SAME disc?
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 23rd Sep 2007, 23:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 17:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 21:31
