I've tried converting an AVI file to DVD using WinAVI and DIKO. Everything seemed to go fine, so I burned onto a DVD+RW. When I played it in my DVD Player, it would play each second, but it would basically freeze at the end of each second for 3 seconds before playing the next second. If I put it in fast forward, it went normally. I can't figure out what else to try. I've read several posts here and every guide I can find. Any help at all greatly appreciated!Thanks.
Try reading about a method which does not use an all-in-one program. You will get much better results. You may also identify the problem the all-in-ones are having, i.e. strange audio format, bad frames etc, and then be able to ask a more consice question.
Could also be a problem with media, burn speed or your player itself.
Read some old posts, try some new discs or try the disc you have created on a different dvd player. -
Originally Posted by Hardcoreruss
If you don't know where the files are search your whole computer for *.ifo then sort by date modified.
.AVI to DVD Jerky Playback
By Bunky in forum MacReplies: 2Last Post: 27th Oct 2009, 13:23 -
how to convert wmv to avi for dvd playback[divx support]
By gundja in forum Video ConversionReplies: 4Last Post: 18th Mar 2009, 12:32 -
Xvid AVI DVD Playback Audio Sync Problems
By lozza_c in forum Newbie / General discussionsReplies: 5Last Post: 8th Jun 2008, 08:38 -
AVI to DVD results in weird playback fault
By JustGreg in forum Video ConversionReplies: 0Last Post: 26th May 2008, 09:51 -
DVD to AVI (DivX) playback strangeness
By vvw in forum DVD RippingReplies: 3Last Post: 11th Dec 2007, 21:34
