i'm wondering because i recently bought a JVC GR-D72U, which is one of the notorious ones that need a TI Chipset in order to work without hassle (the whole workaround takes about 5 mins, if it works). My question is, is the TI chipset any better than my current generic VIA chipset?
I have captured with a Sony DCR-TRV350 (i believe thats the model...its a D8) and a Canon GL1. When capturing in Type 2, i would get audio dropouts here and there for about .5 seconds (you can hear a little bit of silence and then a pop sound afterwards when the audio comes back in). Type 1 gave me less problems.
However, if the TI chipset turns out to be better at fixing this problem (aka, recording Type 2 without screwing up audio while capturing), since my new JVC camcorder nags already, I might as well get one.
Results 1 to 15 of 15
Perhaps Gabriel could help
https://www.videohelp.com/forum/search.php?search_author=Gabriel_BrazilHave a nice Day -
no, that didn't help. gab only found out about the JVC firewire chipset requirement and the workaround for it (which i found out by googling).
my question is asking are the TI chipsets any better at transferring DV video than the VIA ones.
if the answer is yes, i go chuck out a little more dinero for a TI chipset based IEEE1394 card.
if not, I live with the workaround. -
Maybe this will help. When the iPod came out, all the Fwire chipsets that
failed were NOT using TI chips.
So, I'd go with the TI, especially if you have or plan on an ipod. -
lol, i have a first gen ipod and works somewhat fine with my VIA chipset. failed a few times, its just odd. I guess i'll buy the Ti one then.
Hey Folks,
I still canīt capture with my JVC GR-D30....all the applications says that THERE IS NO DV CAMCORDER ON THIS SYSTEM...
I really need help, īcause I donīt have enough money to buy another Camcorder...
Are there any workarounds to JVC Mini-DVs ???
Thanks.... -
Gabriel do you still have that problem..... Is it the camera or the computer? Have you taken your camera over to someones place that has successfully downloaded from their DV camera? Has someone elses camera been tried on your machine? Buy a TI chipset Firewire card.Originally Posted by Gabriel_BrazilHave a nice Day
I tested my Firewire card (VIA) and the cable on another computer with a Sony Camcorder and it worked fine...
I just didnīt have the oppportunity to test another camcorder on my machine...
Iīm thinking about selling my camcorder...I surrender...
And, Iīm from Brazil ... tell me the firewire card models that have the TI chipset on it, ok ?
Thanks for the help ...
Bye...
Could you try your camcorder on your friends machine. Some camcorders are incompatible with some DV cards.
Have a nice Day -
I have an adaptec Duo-Connect 3121 (usb 2.0/firewire combo card) and it has TI firewire chipset on it. There are probably cheaper (and better) cards out there though.
Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
I have tested several chipsets in two different machines and I was not able to tell any difference in performance for Video transfer. I actually transfer the same 35 minutes movie from a digital8 camcorder using WinDV. I created type 2 files.
Tested in a laptop:
- Ricoch: Internal firewire port of my laptop. Worked properly.
- Via: Through a PC card in my laptop. Worked properly.
Tested in my desktop:
- Nec: Chipset used by an Orange Micro card. Worked properly.
- Agere (Lucent): Build in port of an All-In-Wonder 8500DV card. Worked properly.
- Agere (Lucent): Generic and cheap firewire card. Worked properly.
- TI: Tested with an adaptec Duo-Connect 3121. Worked properly.
- Unknown???: Tested the bundled port of a Creative Audigy sound card. Worked properly. -
Both DV and IEEE-1394 are standards and there is not supposed to be any difference in performance from one manufacturer to another. It looks like some compatability issues may still exist but that is it.
Also, Windows XP handles the IEEE-1394 connection and DV camera detection not the application.
Windows Movie Maker 2 DV-AVI import or the Camera and Scanner wizzard camcorder detection are good tests to show XP is working properly for IEEE-1394 DV detection and transfer. -
Theory vs practice.Originally Posted by edDV
Maybe not "supposed to be" but there is.Want my help? Ask here! (not via PM!)
FAQs: Best Blank Discs Best TBCs Best VCRs for capture Restore VHS
Picking a Capture Card chipset, going in circles..
By LukeS in forum Capturing and VCRReplies: 22Last Post: 21st Oct 2011, 08:21 -
Does a Motherboard's Chipset Make a Difference?
By wulf109 in forum ComputerReplies: 1Last Post: 20th Oct 2011, 11:43 -
HP/Compaq D530 SFF Motheboard - Chipset ???
By blinky88 in forum ComputerReplies: 3Last Post: 6th Aug 2009, 15:42 -
Philips SAA7134HL chipset Tv Tuner card !
By ganduman in forum Capturing and VCRReplies: 6Last Post: 5th Jan 2009, 03:43 -
Best tv tuner chipset just for getting channels best
By blitter2 in forum Capturing and VCRReplies: 0Last Post: 26th Dec 2008, 09:01
