i just downloaded the new firmware,,and before i install it i wasd wondering if anyone has had any porblems with it???i read here on another post that they had probs witrh some xvids afterward...has anyone else had this or any other problems with it???
Results 1 to 30 of 45
Check the comments area. Someone posted some concerns about the benefits of the latest firmware.
https://www.videohelp.com/dvdplayers.php?DVDnameid=4117&Search=Search&#comments -
Hmmmm.
I have not upgraded to '1109' yet, but I'm sure that the problem that DereX888 is having, is related to Contrast and Brightness.
I noticed that when I changed firmware from '409' to '531', that I had to change my contrast and brightness settings. '531' seemed darker than '409'. I think that the '1109' firmware may change it back to normal contrast/brightness settings.
Contrast and brightness set too high would definately cause the problem that DereX888 has shown in the picture that he's posted. -
I was just about to try to upgrade the firmware on my 642. I have been having some issues with it but I don't know that this firmware will solve them. #1, the damn thing turns itself on at random moments and starts playing...(it is possible that one of my other remotes that I use is interfering...) #2 the goddamn subtitles sometimes come on automatically. Never the same movie...#3, just found that when there is an angle the little angle changer icon pops up. I can't find a way to turn this off. Also, if when the icon is up you skip a track, the icon will remain indefinitely...
I'm going to try to upgrade and if it doesn't solve any of this, it's goin back.Boy do I love my avatar! -
The firmware upgrade went smoothly and there does not seem to be a PQ difference between 531 and 1109.
I stick to my original assumption that that the problem that DereX888 is having, is related to Contrast and Brightness, and not to the firmware. -
Where did you hear this?
Im thinking about getting this dvd player and wondering if anyone else had anything good or bad to say about the firmware cause if i get this player im sorta scared to put the new firmware on. -
Ok, so whats Global Motion Compensation? is that fancy for multi region?Originally Posted by lifeisfunBoy do I love my avatar!
Contrast and brightness were at their default "Normal" setting when both pictures were taken.Originally Posted by scottymac
Normally I have it set to "personal" settings, where I add a bit of contrast and lower down brightness slightly (to further minimize artifacts appearing on mpeg4 or svcd/vcd).
This new firmware was probably optimized for newest divx (at the time of writing it), because this problem is not as visible on divx5.x files as it is on xvid-encoded files. Best to notice it are the edges of some sharp contrast details, like the station logo I have shown. Perfectly shaped letter "S" in the logo was displayed with original firmware, while suddenly it got artifact bits and pieces around its edges with new firmware. Contrast or brightness has nothing to do with it.
I suggest to buy this player from a retailer with "no questions ask" return or exchange policy, because there is no way to return to original firmware once you upgrade it.
GMC, Q-PEL
no, it does NOT support it. I know, its strange - this machine has ESS Vibratto II chipset, which normally does support GMC and Q-Pel (IIRC i have it in my other player) but for some reason it doesnt work on this machine
Autostarting problems - as someone mentioned it above. My father have same player too, it pick ups signal from his other remote too (Toshiba player) and autostarts if there is a disc inside. Funny thing is that you can turn it on with Toshiba remote from far away, while with its own remote it wont work from half of this distance
Well, we can discuss its shortfalls for long, but IMO for $50 (or less) player its not worth to waste time
EDIT:
I forgot to mention one EXTRA OPTION which is undocumented anywhere: this player plays some ASF/WMV files too! I haven't figured out what are the "proper' encoding settings for WMV to be played on this since i despise this dreadful format, but I was pleased to notice it nonetheless
I was checking my old CD-RW full of good old short porn clips from the web, and among other I had there few asf and wmv file. To my surprise playback was very nice, even aspect ratio was kept proportional on one of them I remember WMP on my PC used to always squeeze it to "very widescreen" screen, while it is 4x3 fullscreen
However other asf & wmv files didn't play at all.
Player just went back to disc menu and message "CODEC. NOT SUPPORTED" appeared on the top. -
I don't think so
The RJ Tech RJ-1500DVXII DVD / CD+G / DivX Karaoke Player is a new multiregional slim-line design player with the latest and most advanced technologies available in home entertainment today. The RJ1500 is not just a Progressive scan DVD Player is upgraded to be able to support CDG format, also it is a Multi-Media player. The RJ1500 is a DivX® Certified DVD Player, making it one of the first DVD players to pass the stringent certification requirements and be fully certified to play the popular DivX® video format from DivXNetworks, Inc. The RJ1500 is based on ESS's Vibratto family of DVD decoder chips. The Karaoke Function allows connection of 2 microphones for karaoke with all formats of karaoke discs! Adjust echo as well as all other karaoke functions.
Features and Specification
1 Year Manufacture's Warrenty
PAL to NTSC built-in converter
Resolved RCE & REA blocking
Progressive Scan
Also plays CDG/MPEG4, XVID, DVD, DVD-R/RW, DVD+R/RW VCD1~3.0, SVCD, DVCD, HDCD, CD-R/RW, JPEG (Kodak) and MP3 formats
Latest Version Compression Format Compatibility: MPEG-1, MPEG-2, MPEG-4, DivX®, XVID and AVI files in ISO 9660 STD
Newly designed super error-correction loader to support /R and /RW discs
Color enhanced pictures during MP3 and CD playback
High-bit/high-sampling (10-bit/54MHz video D/A converter)
Composite Video, and S-Video terminals
192kHz/ 24-bit Audio D/A converter
5.1 3D Surround Sound, Coaxial Digital, Optical Digital outputs
Built-in Dolby Digital, AC-3 DTS and HDCD decoders
Multiple video frame aspect ratio: 16:9 / 4:3
Programmable playback for Audio / MP3 Tracks
Various Karaoke Functions including Key Control
Multi notch fast Forward / Backward Search during Play mode
Still Picture advance Step-by-Step for JPEG mode
Zoom
Multi-angle display
Multiple language subtitles (Captions)
Parental Control with Password Protection
Power: 95 V ~ 240 V (50 /60 Hz) -
well, your source of info is incomplete
It does GMC and Q-Pel, so do other players by rjtech...
Look here:
http://www.rjtech.net/detail.php?model=rj1500dvxii
EDIT:
seems like they removed this page
But you can see description of basically same model only in non-karaoke version:
http://www.rjtech.net/detail.php?model=rj800dvx
"...features with the latest improvement in format support compatible with GMC, QPEL, and PCM audio. Other great features include VGA output, progressive scan, region free, and... "
(it was basically exactly the same text on infopage for 1500dvx before they removed it, as it is on infopage for 800dvx) -
so does this thing support gmc???some say yes and some say no,,also does anyone regret uprading to it,,,i mean if all a sudden xvids look jaggy then whats the point?
ok,i'm trying to upgrade my player,,but when i try to use nero to burn the rom files it says unexpected file formatt,,can i just burn the images as data????please help
to burn the files...read the Firmware Upgrade Readme File here: http://www.usasupport.philips.com/productDocuments.html?ProductCode=DVP642/17&subCat=D...SHQFHKFSESI5P&
Google is your Friend -
The new firmware is fine. 1109 does not introduce any jaggies on any XVID file. I compared xvids before and after the upgrade and there is not one iota of difference.Originally Posted by catdaddio6
I have read numerous forums regarding the 642 and the 1109 upgrade, and the only one who's had 'jaggies' problems is DereX888. Other people have said there's no difference and others have complained about the macrovision, but there's just one member who's talked about problems with jaggies on xvids... -
RJ-1500DVXII does NOT support QPel, because ESS Vibrato II chip does not support it.
RJ-800 DOES suppot QPEL because it's based on Mediatek chip -
Originally Posted by javierperezch
Thank you !
Didn't want to jump at DereX888 back my self
Why not? If Im incorrect then jump right awayOriginally Posted by lifeisfun
Nothing is more pissing than incorrect information, aka misinformation!!
I dont watch many avi files, to me its not a problem if player doesnt support it at all lol
I bought first dvp642 few months ago and i read here on this board someone's complaints about new firmware problems. Since i bought it from one of those retail chains where i could return or exchange it for no reason, so i had nothing to loose to try/check it out myself.
You can read my comment in the dvdplayers section. I dont say anywhere that the new firmware introduces lots of jagginess!
It does somehow distort tiny details on some of the xvid encoded files. It is visible on a rather large screens, like my pic was taken. You have to compare same freezeframe from same disc with old and new firmware. And obviously dont compare on a 30-40'' tv
RJ 1500dvx II plays qpel and gmc no sweat.
Take your own qpel/gmc disc to any store selling them, or to any of your friend who has it, see it for yourself.
I dont care what chip is inside, is it ESS or MediaTek - any info about it I posted here I have read and taken from websites I have posted earlier, most likely www.rjtech.net -
I did try GMC and QPEL on the RJ and it's a no go ....
Link to manual :
http://www.rjtech.net/ManualRJ-1500DVXII.zip -
Youre right!
I just tested qpel and gmc encoded file on RJ 1500 DVX II, and it choke :O -
i followed that,,but nero wont except the rom files,,,what other software can i use???
Nero does accept the rom files. It should be a simple click and drag then hit burn. What kind of error are you getting?Originally Posted by catdaddio6
i do the settings like it says to have them in hte firmware pdf,,then when i try to open the files into nero it says unexpected file format
Firmware problems panasonic dmr ez 27
By rick09 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 23rd Sep 2011, 22:22 -
Help With DVD Driver? Firmware? unknown burning problems..
By spongecake in forum Newbie / General discussionsReplies: 7Last Post: 16th Jun 2008, 17:17 -
Blackmagic Intensity Pro Firmware Problems...
By Jaxel in forum Capturing and VCRReplies: 7Last Post: 3rd Mar 2008, 21:38 -
Samsung SH-S183L firmware update problems
By Dr_Layne in forum DVD & Blu-ray WritersReplies: 1Last Post: 8th Feb 2008, 10:36 -
Firmware problems DVDR70/021
By Xavier in forum DVD & Blu-ray RecordersReplies: 6Last Post: 17th Oct 2007, 23:46
