I've been using TEMPGEnc Plus to encode my Avi's and have followed the instructions and tips of the guides on this site, however when I play my the DVDs i've made (using TEMPGEnc Plus, TEMPGE DVD Author and Nero ) there appears to be blocks on the screen when there is a dark or almost black scene. I wonder if this is considered ghostingor is there another term for this. It only happens in dark or almost black scenes. Its a small problem and I can live with it but if there is some setting I can play around with or another encoder that can do a better job in getting rid of the blocks then I'd like to give it a shot.
I must say that my primary DVD player at this moment is my Xbox.
I use Memorex DVD-R media (from a cake spindle)
If anyone has any tips I'd greatly appreciate it.![]()
Results 1 to 10 of 10
Hi eros28,
What are the settings (particularly the bitrate, if applicable) you're using in TMPGEnc the encoder?There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
It's macroblocks and is caused by using too low a bitrate when encoding, it's probably present in the AVI. To minimize it you must use a high enough bitrate and you can turn on "soften block noise" under the quantize matrix tab.
"Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by ZippyP.
Originally Posted by eros28There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Well I use
23.976 (internally 29.97 FPS) Frame Rate
CBR
The bitrate is the value I get from Bitrate Calculator. For this particular avi the run time is 1:30:34 with a 1.90:1 ratio and a 128kbs/s audio rate is 6607.
I use VirtualDub to save the audio into a wav file and then use TMPGEnc for encoding the video only.
Video format is NTSC (for both the avi and the output) at 9 DC, Motion Estimate Search, 3:2 pulldown when Playback -
Originally Posted by daamon"Art is making something out of nothing and selling it." - Frank Zappa
Mmmm..... 6607 should be OK - especially for totally dark, or nearly dark parts.
I wonder if there's artefacts in these dark parts that aren't visible to the naked eye, but are (very) noisy to TMPGEnc? What d'ya think ZippyP.?
@ eros28 - Try encoding the same footage (or just a portion that has a few mins either side of a problem dark area) but using VBR with:
Max = 8,500
Avg = 6607
Min = 1000
And other settings the same... See how that goes.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Thanks Daamon...I will try that. Do I have to set TMPGEnc to 'Manual VBR'? or Could I try 2-pass (but I guess that will take longer, but with better results I imagine)
ZippyP --> If I enable the "soften block noise" option do I leave the 'intra and non-intra block numbers as is or can I take them up to 40? -
Sorry, I should've said - "2-pass VBR"
Carpe diem.
Sounds like a luminance problem to me (since it is very noticealbe in the black parts).
This is the reason I stopped using TMPGEnc Plus as my MPEG-2 encoder (I use CCE now aka Cinema Craft Encoder).
As for TMPGEnc Plus you might want to try the opposite setting from the default for the "dreaded" option entitled, "Output YUV data as Basic YCbCr not CCIR601"
- John "FulciLives" Coleman
P.S.
If you are doing a 2-pass VBR MPEG-2 for DVD then try setting the MIN at 2000kbps ... setting it lower can cause macroblocks."The eyes are the first thing that you have to destroy ... because they have seen too many bad things" - Lucio Fulci
an anoying problem with subtitles and conversation.
By d2idan in forum Video ConversionReplies: 10Last Post: 13th Jun 2008, 16:54 -
Trying to add a small intro clip to a movie file without re-encoding
By solar2504 in forum Video ConversionReplies: 11Last Post: 19th Mar 2008, 09:19 -
By solar2504 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 18th Mar 2008, 01:53 -
Lower video encoding tips for small 7 inch screen
By hauns in forum EditingReplies: 5Last Post: 9th May 2007, 13:54 -
Small problem psp 2.81
By the posse in forum ffmpegX general discussionReplies: 0Last Post: 7th May 2007, 15:52
