alright, I had some .avi divx files and I used tmpg to make a dvd complient .mpg and there is no sound.. none on the .mpg or the burned dvd I made... also, the picture gets funny thick block lines across it sometimes. any idea wtf i done wrong?
AnonymousGuest
1. Identify WTF you have
2. a) Extract the audio of WTF you have if WTF you have is VBR MP3 audio, then convert as per 2. b)
2. b) Convert the audio of WTF you have if WTF you have is not VBR MP3 audio
3. Convert the Video of WTF you have to a DVD-compliant video
4. Let your authoring software join together the video part of WTF you have which you encoded in 3. with the audio part of WTF you have which you extracted/converted in 2.
5. Burn WTF you just authored.
If in doubt, Google it. -
AnonymousGuest
man, the WTF are throwing me off.. lmao, whut i read on the TMPG templet that it was going to convert the audio for me possibly... when i loaded the videos into tmpg dvd author, and it said i didn't have an ac-3 codec, could that be the problem? thx man.
Sound problems
By maltipom in forum Newbie / General discussionsReplies: 2Last Post: 16th Mar 2009, 14:37 -
sound problems
By deebo in forum Software PlayingReplies: 4Last Post: 9th Aug 2008, 15:43 -
Problems when I try to add subtles in my video on TMPG DVD Author 3
By ihmcjacky in forum Authoring (DVD)Replies: 4Last Post: 22nd Mar 2008, 02:24 -
Sound problems
By zewzeq in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 20th Nov 2007, 07:36 -
avi2dvd sound problems
By justmenow55 in forum Video ConversionReplies: 5Last Post: 13th Aug 2007, 03:58
