  1. Member rhegedus's Avatar
    on the jazz
    Can I rip a DVD so that a subtitle stream is forced during playback?
    Regards,
    Rob
  2. Member 888888's Avatar
    Jan 2004
    Turdistan
    Yes. When using DVD Shrink, right click on the title you want and select "Set Default Streams". Under Subpicture, select the one you want to play as a default. Very useful in foreign language films.
    This question is DVD to DVDR btw, not DVD Authoring. :P
  3. Member rhegedus's Avatar
    on the jazz
    Thanks for the info.
    Regards,
    Rob
  4. Member jeanl's Avatar
    Sep 2004
    CA, USA
    well, does that guarantee it will be "forced"? I understand that makes it the default one, but I'm not sure it turns it on by default.
    If you want it on by default, that's an easy job with PgcEdit...
    Jeanl
    MenuShrink a free tool to shrink menus into stills with or without audio!
    DVDSubEdit: a free tool to modify your subtitles directly inside the vob.
  5. Member rhegedus's Avatar
    on the jazz
    Sorry - I've not used PgcEdit before
    How do I turn on subtitles as default?
    Regards,
    Rob
  6. Member jeanl's Avatar
    Sep 2004
    CA, USA
    Essentially, you would add a SetSTN command in the pre-command area of your movie PGC. If you're totally new to this, you can check out a guide I wrote for jumping straight to the movie.
    It explains how to find your movie PGC, how to add commands, and even says a few things about changing subtitles and audio...
    http://jean.laroche.free.fr/
    Jeanl
