Thread: WinTV250 PVR(PCI) encoders?
  1. #1
    Member
    Dec 2004
    Canada
    Posts
    13
    I was wondering if anyone knows of any encoders (if that's what they're called) that work with the WinTV cards. I want to be able to capture in formats other than mpeg2. I use Pinnacle Studio Plus 9 to edit and it's capture mode does not work with the card for some reason???
    Member BrainStorm69's Avatar
    Aug 2002
    Texas, USA
    Posts
    821
    A WinTV PVR can only capture in mpeg-2 format. It's hardwired -- ie, the encoder is embedded in the chip on the card.
    Member yoda313's Avatar
    Jun 2004
    The Animus
    Posts
    21,013
    Hello,
    Ditto.
    The wintv pvr 250 is MPEG only. That is what it was made for. And it does this very well. But nothing else. It's just for easy high quality mpeg captures for vcd/svcd/dvd. No more, no less.
    Kevin
    Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Posts
    11,301
    One option that some people do with these cards ...
    Capture at 15,000kbps which is the highest video bitrate these cards are capable of.
    This will give you a very high quality capture that can be re-encoded with a software MPEG-2 encoder so you can edit beforehand then do a true multi-pass VBR MPEG-2 encode.
    But eventhough 15,000kbps is very high for the MPEG-2 format (at standard DVD resolution) it still is not a lossy capture unlike using say HuffyUV via an AVI capture. However this "trick" does seem to work well since although the capture is not "lossless" it still is very high quality without any compression artifacts, at least not to even the best of human eyes.
    - John "FulciLives" Coleman
    P.S.
    These only capture MP2 audio with 384kps being the max bitrate. I think the internal models (like the 250/350 models) have a hack that allows PCM WAV audio on capture but I've heard that doing that hack and keeping A/V sync is near impossible.
    Member
    Dec 2004
    Canada
    Posts
    13
    Thanks everyone! That helps
  1. PVR files on a PVR formatted disk
    By keithy in forum Newbie / General discussions
    Last Post: 22nd Apr 2009, 08:26
  2. Replies: 4
    Last Post: 23rd Mar 2009, 00:21
  3. Asus PCI PVR-210 FM drivers can't be found for XP ?
    By MidnightMike in forum Computer
    Last Post: 22nd Jan 2009, 09:05
  4. Hauppauge PVR-350 vs PVR-500MCE
    By dphirschler in forum Capturing and VCR
    Last Post: 11th Mar 2008, 09:04
  5. Replies: 0
    Last Post: 24th Jun 2007, 11:58
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
