  1. Guys, I have a problem.
    I've got a DVD that is two-sided (not double layer, two-sided) and it contains a series of episodes. There are 3 on each side of the DVD. Each side is about 3.0 GB and what I need to copy it all to a single DVD-R, a 4,7 single-layer. What do I need to connect those two sides (or two DVDs, that's the same case) ?
  2. Is it important that you have a menu on the DVD?
    If God had intended us not to masturbate he would've made our arms shorter.
    George Carlin
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    If you don't care for menus, DVDShrink in reauthor mode is probably the quickest/fast/most noob-friendly way to do it.
    If you want a menu, I'd use TMPGEnc DVD Author and the Add DVD Video button. Then you can create a menu, and once you're finished outputting, run it through DVDShrink or DVD2One to trim back the size.
    If in doubt, Google it.
  4. Thanks for your advice, guys.
