Once in a while it happens that the converted mpg + menu don't fit on the DVD.
couldn't there be a way to give a warning before starting the process?
Similar like in Nero, which shows me who full my media is.
it is something i will be implementing but it will be a guideline only (i.e an educated guess)
to be on the safe side, i make my assets a total of 4 gigs...... for instance... if i take an SGA episode that is xvid... i load it into mainconcept encoder and adjust the bitrate and setting to make it an mpeg2 about 1 gig in size... so that when i put 4 episodes on it, its 4 gigs in assets....
if you do svcd movies, you may have to mess with the audio type.. from layer 2 to stereo.. layer 2 adds alot of size versus stereo.... but it depends on your taste...
or you could just create your high quality DVD files and if they are like 5 gigs or so then use Intervideo Dvd copy to select the folder and make it fit on a dvd.... i use this because it maintains quality pretty good...
blayze
A Question On How To Calculate Frame Size When Resizing Vid for DVD
By hydrophonicaudio in forum Newbie / General discussionsReplies: 13Last Post: 21st Feb 2011, 07:53 -
How do I calculate the size of the converting video?
By s_joy09 in forum Newbie / General discussionsReplies: 4Last Post: 14th Aug 2010, 09:45 -
How to calculate the sample size of wmv Video file
By asifjavaid in forum Video ConversionReplies: 3Last Post: 13th Apr 2009, 08:33 -
How to calculate size of video file after encoding?
By vid83 in forum Newbie / General discussionsReplies: 3Last Post: 31st Dec 2008, 01:56 -
calculate the size to save
By Cazz in forum EditingReplies: 7Last Post: 11th Jan 2008, 06:05
