I've been trying to encode a XviD encoded avi video to mpeg 2 dvd d1 (ntsc) with avidemux on my slackware distro, with mixed results. First off here are my settings:
version 2.0.34
Video:
- vfilter DVD Resize to NTSC res
- vprocess on
- XSVCD- lavcodec with single pass and 8000 bitrate
- change fps from 25.0000 to 29.97 (ntsc)
Audio:
- ffmpeg (mp2) stereo 128kps
- vprocess on
I then went to file, save, save video, and saved my video as video.m2v.
I then went to audio, save audio, and saved it as audio.mp2
After encoding I opened the video.m2v file in avidemux and then indexed it with mpeg audio, because I would add that later. I then went to audio, source, and added my external mp2 audio from audio,mp2. I then turned off aprocess and vprocess and then went to save as DVD PS, and saved it as video.mpg. I then tried playing it and noticed a few problems:
- The video quality of the encoded mpeg is not as good as the original avi, even though I had a high bitrate. Why is this and what can I do to fix it?
- The audio would just cut out after a short amount of time... I tried playing audio.mp2 and it played fine all the way through. What is wrong here?
What should I change in my process so I can successfully create an mpeg 2 dvd file from an avi?
Thanks.
Garibaldi
Results 1 to 1 of 1
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 21:02 -
Avi resizing or creating quick dvd using avidemux
By striker9 in forum Video ConversionReplies: 13Last Post: 2nd Nov 2010, 11:01 -
Cant convert Pal .AVI to NTSC DVD in Avidemux
By Hittz in forum Video ConversionReplies: 6Last Post: 5th Nov 2009, 07:43 -
MPEG-limitations in AVIdemux?
By Gew in forum EditingReplies: 9Last Post: 9th Apr 2009, 08:55 -
how do i convert the exact same AVI file to DVD on avidemux?
By whodini in forum Newbie / General discussionsReplies: 4Last Post: 20th Jan 2008, 19:14
