Hi,
After many problems with my Pioneer DVR-5100HS dvd recorder I have decided to sell it and buy a new dvd recorder.
I used to have a Panasonic vcr which was quite good so I might buy a Panasonic dvd recorder.
Which one of these is worth buying, I am prepared to spend up to £800:-
PANASONIC DMR-E85H - PAL FORMAT
PANASONIC DMR-E95H - PAL FORMAT
PANASONIC DMR-E100H - PAL FORMAT
I might also buy a Panasonic VCR to use with the dvd recorder to archive my PAL and NTSC vhs tapes (commercial and non-commercial), which one should I buy.
Thanks.
if you are after the video as well why dont you get this one Panasonic DMR E75VEBS
it might be just as good
Looking for sound card recorder (not Total Recorder)
By jimdagys in forum AudioReplies: 1Last Post: 7th Jan 2011, 20:23 -
DVD Recorder/VCR With No Tuner - Link to Broken Tunered DVD Recorder
By Surfmaster in forum DVD & Blu-ray RecordersReplies: 1Last Post: 23rd Dec 2008, 03:05 -
Will a DVD-Recorder to DVD-Recorder copy lose quality?
By blackmetal in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2008, 05:54 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59 -
Toshiba RD-KX50 DVD Recorder / HDD Recorder
By Kinddomaker in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jul 2007, 22:19
