Hi Guys
Need a bit of advice/Help with some video encoding.
I have various Avi and MPG files to convert.
At the moment i use Tmpgenc plus to encode them into DVD Pal files and then add to Ulead Dvd workshop to make the the menus and encoded the final vobs.
As the files are already compliant for ulead it doesn't bother encoding them. I used to use ulead to do the full process but it takes ages from start to finish, Tmpgenc doesn't take as long but sometimes the files when encoded have no Audio.
I want to keep using Ulead for the menus and they are better than anything i have seen and the options in it are great but i am trying to find something to encoded them from/Mpeg to dvd pal mpg.
I have got the full version of SVCD2DVD but that doesn't seem to convert them to dvd pal compliant files (or at least as ulead is concerned) , I've tried various other ulead packages and also a few other encoding programs but all seem to have unhelpful results.
Anyone got any recommendations for software to convert from AVI/MPG to Pal DVD files that doesn't take a week to do and gives good results?
Not authoring. Moved...
AVIDemux is a good free mpeg2 converter
get it herehttp://download.berlios.de/avidemux/avidemux-2.0.34-test2_win32.zipThere are many ways to measure success. You just have to find your own yardstick.
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 15:46 -
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 18:44 -
AVCHD encoding format vs. H.264 encoding format?
By coody in forum Authoring (Blu-ray)Replies: 3Last Post: 28th Aug 2010, 21:51 -
Encoding MKV to MP4 with .ass subtitles without re-encoding.
By smilegreen in forum Video ConversionReplies: 7Last Post: 26th Apr 2009, 15:11 -
Best settings for encoding with subtitles and then re-encoding for PS3?
By bish73 in forum ffmpegX general discussionReplies: 5Last Post: 21st Jul 2007, 01:31
