I have been downloading for some time and burning to dvd, but I have just come across this file extension which the computer does not recognise:
filename .001 File
this is repeated all the way to
filename .094 File
What should I do with them.
Cheers
Results 1 to 11 of 11
open the first 001 with winrar, http://www.rarsoft.com/ .
it's also possible....especially if .001 is last part of full name of file, that it was video split with a program call HJSplit (I think that's the correct name)
there are a few programs that split/join files.. files with extention 001 002 etc are mainly done on usenet.. but thats besides the point.. any filejoiner will rejoin them.. i used one called joiner32 in the past.. that will join them to one main file.. and that might be an iso or zip or something.. maybe a movie file too..
but you prolly already knew that huh? haha..
That also happens when you run a hard disk utility and it finds and repairs a file. Some of them use the 3-digit numerical designator as a default extension.
i have the same problem ,i tried open the files with winrar but i got the message no archive
i tried to join the files with filemerger and BLjoin and when i try to open the file i get the message doesn't reqognize ! -
Try renaming the files and see what happens...
.001 File to 001.avi
.001 File to 001.mpg -
Originally Posted by nokiatune2001
Do you remember where you downloaded them from? Might be easier to help if we had the same file to work with.
J4F file extension
By mariestalet in forum Newbie / General discussionsReplies: 5Last Post: 17th May 2009, 03:53 -
New File Extension To Convert
By EDS001 in forum Video ConversionReplies: 6Last Post: 20th Mar 2009, 16:59 -
Converting to new file extension
By Nitro89 in forum Video ConversionReplies: 11Last Post: 17th Apr 2008, 12:42 -
What would cause the file extension icon to come up empty?
By Captain Satellite in forum ComputerReplies: 22Last Post: 14th Nov 2007, 19:17 -
wht is the .ff file extension
By modular1 in forum ffmpegX general discussionReplies: 3Last Post: 9th Oct 2007, 05:05
