Help!!
I was told to use Virtualdubmod to edit out commercials and re-encode my MPEG2 TV caps as Virtualdub didn't support it. I went to Source Forge and got the latest release (1.5.10.1) but when I try to use it, there's no drop down list for audio to the right of the one for video and I can't seem to find any place in the program to enable it.
Thanks,
kyleinct
In VirtualDubMod the Streams -> Stream list menu is where you find the audio stuff.
Yes, using VDubMod to edit mpeg2 was a bad advice. You can only save as AVI or frameserve to encoder to reencode as mpeg2 again, reducing quality.
Womble mpeg vcr is the best option, as freebird says. Cuttermaran is often recommended too.
Or if you are going to create a DVD, you can cut stuff out in TMPGEnc DVD Author...
/Mats -
thanks for the replies -
the problem still is - how do i compress audio in virtualdubmod?
do you do it in a different way than you do in virtualdub?
kyleinct ("still looking for that perfect encoder") -
Streams -> Stream list -> right click on the audio stream -> select full processing mode -> select compression -> select and configure audio codec.
I assume you're converting to DivX/XviD with MP3 audio, otherwise you're definitely better off with an MPEG editor like the others suggested. VideoReDo is another excellent MPEG editor. -
thanks!! that helps a lot!!
one more question -
my mpeg2 source3 video plays really choppy when i play in vdubmod - is this normal?
-kyleinct[/quote] -
Without filters it shouldn't be choppy. The filtered preview can be choppy. Select a small section and convert it. Then play the resulting AVI. If the AVI isn't choppy, everything is fine.
Audio encoding to VirtualDubMod
By Jpal in forum AudioReplies: 2Last Post: 21st Feb 2011, 11:01 -
virtualdubmod no audio problem
By hell in forum Video ConversionReplies: 0Last Post: 4th Jan 2010, 17:49 -
VirtualDubMod - No audio decompressor
By MrFriendly in forum AudioReplies: 5Last Post: 4th May 2009, 00:11 -
virtualdubmod audio problem
By aruwin in forum EditingReplies: 4Last Post: 18th Oct 2008, 02:08 -
VirtualDubMod - Does it keep audio sync?
By vodmare in forum Video ConversionReplies: 4Last Post: 13th May 2008, 02:15
