I burned a VCD using Nero... but video is not sync with the voice...
Was it in sync before you burned it ?
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
if it was go to the FAQ Section on the left and search for soloution for Sync problem and that should help you out
I have the exact same problem. I downloaded 2 AVI files and used Nero 5.5 to burn two separate VCDs.
The sound on both VCDs is out of sync with the video. I tried two different VCD palyers and have the same
problem. The original AVI files are in perfect sync.
I just got started with this crazy obsession this past weekend, so I am a true novice.
I also have two AVIs that immediately after downloading (no burning or converting yet) have video trouble.
Using Windows Media Player, they both play audio in a "tinny" sound with no picture.
I tried changing my monitor resolution and color settings, but no luck.
Does anyone have any suggestions?
Thanks in advance for any help.
phawkcpa, did you use Nero to encode AVI ? or did you use a real encoder ? it all depends on that small little detail, of who and how.
Best Regards,
Sefy Levy,
I have found using nero that if I burn at max speed, 16x, I somtimes have sync and even video break up, since I started lmiting my burning to 8x I have had neither problem for over 6mo and 50 movies. Maybe it will work for you.
Problems with voices out of sync
By Jimbo1 in forum Video ConversionReplies: 4Last Post: 25th Apr 2011, 05:32 -
problems with sync
By joachimfreitag in forum MacReplies: 5Last Post: 10th Sep 2009, 15:00 -
wmcapture sync problems?
By the_doc735 in forum Video Streaming DownloadingReplies: 2Last Post: 6th Apr 2009, 15:32 -
Audio sync problems
By jelockwood in forum ffmpegX general discussionReplies: 1Last Post: 30th Jul 2007, 12:03 -
Audio sync problems
By alvinboobar in forum Video ConversionReplies: 1Last Post: 10th Jul 2007, 06:22
