  1. I'm reading about all sorts of formats for DV and how you "capture" it (transfer via firewire). What I'm wondering is this: If I an using a sony mini DV camcorder is there a standard format my VD is in? Is there a "best" format to set for capture?
    If using TMPGenc to encode to DVD format, is there a recommendeed format I want the AVI file in? Do I just use whatever is "normal" for the Sony DV Cam?
    Also, won't all my files be the same if they come from the same source? How 'bout when I run my analog through my Sony DV to convert to firewire transfer - same format or different?
    Thanks.
  2. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    I believe DV is already 720x480 which is the standard Full D1 DVD format. Just go with that.
  3. Normally i think the format is AVI. Not compressed like DivX or Xvid, but the relatively uncompressed DV-AVI. Takes up about 13 GB per hour of footage
    The distance between genius and insanity is measured only by success...
  4. Member MpegEncoder's Avatar
    Dec 2002
    Wish I was on Catalina Is
    DV compression is still 5:1
