Hi. I have found guides on how to crop an avi file using v-dub. This works fine, but is it possible to keep the my avi file in DV format. The avi file using 'no compression' in v-dub makes the file HUGE.
thank you.
If you are going to encode this as mpg2 for dvd then just frameserve it.
When you saved in DV "format", you must have specified a codec to use. In virtualdub, specify this codec instead of "no compression". Job's right
If in doubt, Google it. -
It was origonally saved in DV format when I captured it into premier. I see the codec now. thanks.
If I re-save this file (cropped) using the dv codec, will this make the video file lower quality or will the quality remain the same?
Converting/cropping QT to AVI for powerpoint
By cdragin in forum Video ConversionReplies: 1Last Post: 13th Oct 2009, 11:00 -
cropping avi
By wingfan in forum EditingReplies: 5Last Post: 16th Dec 2008, 23:37 -
Problem when cropping avi
By baconharvester in forum EditingReplies: 2Last Post: 15th Sep 2007, 20:43 -
Cropping avi tool needed
By rindless in forum Video ConversionReplies: 6Last Post: 29th Aug 2007, 03:18 -
cropping a avi
By aanfield in forum Newbie / General discussionsReplies: 3Last Post: 21st Aug 2007, 17:09
