I am looking for a recommended program to convert mp3 to wave. Something, fairly simple and fast. How will this sound since basically I will be taking a compressed format and uncompressing it? At least that is what I think I am doing, if I understand correctly. I want to convert the mp3 to wave , so I can use it in my video editing program that will not accept mp3 format.rikit
Results 1 to 11 of 11
There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
I generally use Headac3he because I use it for everything else. CDEX is great. My personal recommendation is SCMPX.
http://www.din.or.jp/~ch3/index_e.html
Very fast high quality, also converts mp2, batch processing, very fast high quality mp3 encoder, player and integrates with TMPGenc, runs on anything from a 486 upwards, very tiny and compact. A marvelous piece of programming. -
OK, I'll third CDEx. The sound quality will be exactly as the MP3 - the degradation happens when you go from an uncompressed (wav) format to a compressed (mp3) - not in the other direction.
/Mats -
BESWEET, and it's free.
How to Convert 2 channel stereo wave into DD5.1 AC3 448 / AC 640
By Bonie81 in forum User guidesReplies: 36Last Post: 2nd Feb 2018, 13:42 -
Convert DVD to WAVE
By edu-write in forum DVD RippingReplies: 1Last Post: 14th Dec 2008, 10:48 -
Weird wave/MP3 file
By AlanHK in forum AudioReplies: 2Last Post: 20th Nov 2008, 01:33 -
command line MP3 to WAVE?
By AlanHK in forum AudioReplies: 5Last Post: 1st May 2008, 07:10 -
Turning DVD chapters in to MP3 or wave files
By ericshogan in forum DVD RippingReplies: 7Last Post: 8th Aug 2007, 17:03
rikit
