Hello Forum Members, I want to get a better Capture Card and have been looking at the Canopus ACEDVio ($359-list/NO Software). I also plan on using Sony Vegas 5 to do the capturing (already have).
I'm also curious if Scenalyzer would work with the Canopus ACEDVio Card?? Or what other software I could use to capture as an auxilary program. Would Premier 6 work?? Anyone....!
I mostly capture from VHS or S-VHS tapes.![]()
Does this sound like a Great setup????![]()
Good Setup????![]()
Poor Setup???![]()
Any comments appreciated.
Thanks to All who respond.
Doc_B
Reach for the Starz
I was lucky enought to get the ACEDVio when it came bundled with Vegas 4. Canopus was the end of a long search to find a solid capture solution. One thing I did not like about the card is the inputs. One S video witha RCA converter just don't cut it.
As far as other software, Vegas is all I have needed so far. Works great! I can say that your computer will see your card as basically a firewire device so any software that edits AVI and can capture firewire should work. -
Hello Pat Brown, Thanks for your reply. I too saw the inputs as being the weak point. Although, I've been capturing to the computer for over 3 years now and for the most part all I've needed are regular RCA inputs. I've only used an s-video input a few times.
Once I connect the RCA to the s-video inputs - is the connection a solid one???
Thanks...
Doc_BReach for the Starz -
Yes the connection is tight. I put an over hand knot where the s video connects to the adapter but this is not necessary iguess.
I have a S-VHS connected to the card. This offers conversion and has front composite and S-video ports. This keeps me from having to switch cables around.
Is Sony Vegas Movie Studio HD Platinum 10 a good editing software?
By vid83 in forum EditingReplies: 8Last Post: 4th Feb 2011, 08:02 -
Help with setup 7.5 IRE in VEGAS
By mirek in forum EditingReplies: 10Last Post: 10th May 2010, 14:27 -
Save as good as possible in Sony Vegas Premium 9
By Cazz in forum EditingReplies: 2Last Post: 4th Dec 2009, 18:15 -
Good setup for home movies and Tivo?
By lened in forum Newbie / General discussionsReplies: 0Last Post: 21st Dec 2007, 21:41 -
Need a H-Quality AVI to MPG BATCH converter - As good as Sony Vegas
By Ratman in forum Video ConversionReplies: 3Last Post: 18th Oct 2007, 13:42
