Results 1 to 29 of 29
  1. Taiyo Yuden White Inkjet Hub Printable 8X DVD-R Media in tape wrapped spindles
    Ratings:
    Product Code: DVD01X0166
    Manufacturer: Taiyo Yuden
    Mfr part #: DVD-R47WPP600SK ,,,,,supermediastore is selling these,anyone used any or even know if they are real?
    They are real if sold as TAIYO YUDEN
  3. Thanks for the answer lordsmurf
  4. Originally Posted by kenowell
    Sold as.. but what are they I have yet to see any TY hubs.
  5. Let me know if you ordered these, because I did, and then had them replaced because I thought they sent me the wrong ones (not hub printable as described). The replacements they sent were still NOT hub printable, so I would LOVE to know if you ordered these, and if so if they were Hub Printable. Thanks!
    May 2004
    HatchetMan, those discs might have a TY media code, but they aren't Taiyo Yuden discs.
  7. Well they have worked beautifully thus far, so who cares?
    May 2004
    People who want actual Taiyo Yuden media would care...
  9. Because why? I've gone through hundreds of TY's in the past from supermediastore and meritline and still can't tell the diff. It's good stuff, and was fairly inexpensive, hence most bang for the buck comment!
    May 2004
    Genuine Taiyo Yuden DVD media (which is made in Japan) is among the highest quality media available, which is why there is such a fervor to obtain it. Lower quality manufacturers will often use TY media codes because using their actual media codes often results in the discs being limited to lower speeds in many burners. The drive manufacturers purposely limit the speeds on those discs because their quality is not that great.
  11. Limited to lower speeds is many burners? I successfully burned it @ 8x, all the way to the end, past the 4GB mark (that's the only speed I tested it at since that was the highest manufacturer rated speed)! I'm only commenting on what I know about the media since I appear to be the only to have tested it (though I know of at least one other with it that will also be testing it very shortly). The Lord of the Rings: Return of the King: Special Extended Edition looked splendid, I watched it last night.
    Media Information
    Region information N/A not a DVD-VIDEO
    Media code/Manufacturer ID TYG02
    Format Capacity Blank Disc
    Free Blocks 411107328
    Free Capacity 4.38GB(4.71GB)
    Book Type DVD-R
    Media Type DVD-R
    Manufacturer Rated Speed 8.0x 11080KBps
    Available Write Descriptor CLV 16.0x 22160KBps
    Available Write Descriptor CLV 12.0x 16620KBps
    Available Write Descriptor CLV 8.0x 11080KBps
    Available Write Descriptor CLV 6.0x 8310KBps
    Available Write Descriptor CLV 4.0x 5540KBps
    Write Strategy Speed 4.0x 5540KBps
    2x Speed OPC beta 08
    2x Speed OPC power 0E
    2x Write Strategy field 1 11 87 78 80
    2x Write Strategy field 2 88 80 00 00 00 00
    4x Speed OPC beta 06
    4x Speed OPC power 13
    4x Write Strategy field 1 0D 10 0E 07
    4x Write Strategy field 2 97 07 0D 0B
    4x Write Strategy field 3 80 00 00 00
    4x Speed OPC beta multi-pulse 06
    4x Speed OPC power multi-pulse 18
    4x Write Strategy field 4 17 85 78 75
    4x Write Strategy field 5 D6 89 A8 92 01 20
    4x Write Strategy field 6 10 00 D0 00 00
    Data area starting sector 30000h
    Linear Density 0.267um/bit
    Track Density 0.74um/track
    Number of Layers 1
    Complete Media Code
    00000000 00 6C 00 00 01 40 C1 FD 9E D8 52 00 02 87 0D 10 .l...@....R..... 00000010 66 78 80 00 03 54 59 47 30 32 00 00 04 00 00 00 fx...TYG02...... 00000020 00 00 00 00 05 AA A2 22 22 20 02 00 06 08 0E 11 ......."" ......
  12. Member Skith's Avatar
    Bottom of the ocean
    Take a look at this thread over at CDFreaks.
    Fake TY media with a TY media code is NOT TY media. No reputable company would put another company's media code on their discs. Doing so is not only deceptive, but illegal.
    There are more threads on CDFreaks discussing this. One of the only ways to know if a disc is truely TY (that I know of), is to look at the serial number printer on the inner ring (look at the bottom of the disc).
    Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
  13. Member Skith's Avatar
    Bottom of the ocean
    weird... how did I end up quoting my own post and turning it into a repeat?
    well, repeat info deleted, and you get to read this instead.
    sorry for the off topic.
  14. Funny, I had no errors w/ sonic, my scans were excellent, better than the fuji I just finished off and better than the tdk I had just started. In fact, they were same as the silver thermal printable ty's I have stockpiled. Guess I just lucked out.
  15. Rima is offering hub printable Ty's now.
    http://www.rima.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=R&Product_Code=1760-1...tegory_Code=GP
    With their reputation I'd have to believe these are the real deal. I've just put in an order, I'll post back when they arrive.
    Jan 2002
    n8patrick
    I ordered some of these and they are not hub printable.
  17. Order arrived from Rima today. Looks like we have the real thing here. TYG02 media code, UM417A04641GG serial number around a 22mm hub.
  18. I ordered those from Rima last week, should recieve by Wednesday (I hope no later than that!) I will let you know if I have as good of luck with them being the real hub printables!
  19. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    The reason I want genuine TY not some fake crap, Hatchett - is simple.
    Sonic's fake-o's might burn at 8x - but what about 16x, which is what I burn my TY's at? I can almost *guarantee* a horrible disaster of a coaster with sonic's.
    And you pay more for TY, so why would you pay more, for something generic?
    Seth
    :star: :star: :star: :star:
    Archived DVD Scans
    Nero V ImgTools V Decrypter
  20. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    n8patrick..have you recieved them yet? How they doin if so?
    Seth
    Archived DVD Scans
  21. Well, I recieved my order today, and YES! Thank God, they are finally the right thing. I think I am shopping with a new company from now on. I recieved 100 full hub printable DVD-R TY's from Rima. Anyway, thought I would let you know!
  22. I just had to post after using these TY's that I recieved. Let me say, they are GREAT! I had also recieved some Ritek full printables (which I ordered before hearing that Rima had these TY's in). Well I had some issues with the project I am trying to get out for Christmas when burning to the Riteks. So I got my TY's and used them, all 7 have worked great! Clean burns! And better than that, using my Epson R800 Printer to print onto these, I must say they look like what you get from hollywood, no bs! I am very pleased, and think I have found the media of choice as long as they don't change em or screw em up!
    Anyway, just wanted to share my good news!
  23. Good news indeed. Haven't had a chance to check out the print surface yet but I've gone through about 20 so far and couldn't ask for better burns. My main reason for straying to other brands was hub printing and I would have good luck with a Prodisc, Ritek or Beall for a while, but bad batches would pop up far too often. A problem I have yet to experience with TY's. Now that they're offering true hub printables I have no reason to switch other than the occasional whimper from my wallet.
  24. Mine just arrived today. The burning is good but the printing surface is rough (like paper). I would prefer the ritek printing surface more than the TY.
  25. Agree on the TY finish, but you can't beat the burn. Haven't tried the hub printables yet, though.
    I still stand by the Maxell printables for overall burn/print quality. Tough to beat, although they don't come hub printable. Ritek has a strange opaque look that is good for some prints, but cartoonish for photo type output (unless they changed the recipe lately). I've ordered some Verbs, 8X, hub printables to try. I'm hoping those will compare well to the Max's.
  26. I just received 2 TY hub printables from RIMA as a sample they sent to me for a test burn. They have the 22 mm hub, but no serial code printed on them. Otherwise, they have the TYG02 media code and all. Anyone else working with the hub-printables with no serial code?
  27. Member
    May 2004
    You should be able to see a serial on the dye side of the disc...
