Everything goes fine with the beta until I get to the where it says, "Burning DVD Folders." At that point, I get the following error message:
Type: System.InvalidCastException
Source: System.Windows.Forms
Message: Specified cast is not valid.
InnerException:
StackTrace: at System.Windows.Forms.Control.MarshaledInvoke(Contr ol caller, Delegate method, Object[] args, Boolean synchronous)
at System.Windows.Forms.Control.Invoke(Delegate method, Object[] args)
at System.Windows.Forms.Control.Invoke(Delegate method)
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
Any ideas as to what is wrong? I am able to take the file files and burn them with Nero but prefer the internal burning process with CopytoDVD. Thanks.
This is apprently a Windows error...
That error means you are trying to cast one data type to another and it doesn't like it.
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/cpref/html/frlrfsyste...classtopic.asp
Just a piece of info for you but I know I have not solved your problem. :P -
Indeed.
My guess is however is that the SVCD2DVD window was not in focus at the time.... Can you repeat and keep it in focus to see if you get this again?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Audacity 1.3 Beta (Unicode) - Installation Error
By GT Music in forum AudioReplies: 4Last Post: 24th Jul 2009, 11:46 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 21:18 -
When burning DVD error message about AC3 files keeps coming up
By blueedlilly in forum DVD RippingReplies: 7Last Post: 13th Feb 2008, 12:23 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 17:41 -
NERO gives me error message when burning DVD
By qwazi in forum Authoring (DVD)Replies: 8Last Post: 10th Aug 2007, 02:01
