    Aug 2002
    Goal is to take a series of pictures from a digital camera and make a NTSC DVD slideshow to play on a fullframe TV.
    According to an article here:
    http://www.uwasa.fi/~f76998/video/conversion/
    I should take my original pictures, crop them to a 4:3 ratio, resize them to 704x480, then add 8 pixels of black border to each side to make it 720x480.
    So I'm trying to find a way to do all that.
    Cropping is easy enough, although time consuming but I don't want to crop each picture at the same place so I think I'm stuck here cropping each photo seperately. I downloaded Irfanview which makes batch resampling to any size easy (Under advanced options, check resize & enter the desired size and also check the resample box)
    So now I have a bunch of 704x480 JPG files. Now how do I make them 720x480 with 8 pixels of black borders on each size? Any way to do it with an automatic process rather than edit each picture individually?
  2. Member daamon's Avatar
    Melbourne, Oz
    Check out Slide Show Movie Maker. I've not used, but have seen loads of people recommending it and very happy with the results.
    I'm guessing that it's a case of "Load JPGs" -> "Buil Slideshow" -> "Get output".
    Go for an AVI output which can then be encoded using your chosen MPEG2 encoder.
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
  3. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    you could do it with Photoshop - open the first picture and record your actions, then run that action as a batch process on the folder containing all the rest of the pics.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
    Aug 2002
    Thanks, will look into it, but I'm trying to get the photos in the right resolution before putting them into a slide show program. Found out the hard way that not every program does a good job with resizing which is why I'm trying to do it myself.
    Aug 2002
    To close this out, here's what I did to be able to do this:
    I individually cropped my photos to a 4:3 ratio and used (freeware) Irfanview to batch resample all of them to 704x480.
    I was able to use the following AviSynth script within Vdub to update a series of JPG files (named name (0).jpg, name (1).jpg etc) :
    ImageSource("d:\TEMP\name (%d).jpg",0,10)
    AddBorders(8,0,8,0)
    ImageWriter("d:\TEMP\",type="jpg")
    This created files 000000.jpg thru 000010.jpg after I chose 'preview output from start' in Vdub.
    The above script padded them out to 720x480
    Jun 2004
    Ferrara-Italia
    This is ok, the only thing is that you're slightly distorting the image proportions, since the 4:3frame you cropped was resized to 704x480, but you're actually authoring at 720x480. You're shrinking horizontally by some 2%. If you intend to keep the 8pxl padding left and right, to preserve the proportions you would have to crop the orignals to a 1.304-width-to-height frame.
    I hope this was clear enough
    Sorry, I had to go see about a girl
