Hi
I am new to this so please bear with me. Is it possible to save a small animated clip that you can only watch if you are connected to the web and plays through a flash player, when I right click on it I do not get any options to save, if I go to edit and click save as, it only saves the web page and I can only get the clip up if I am connected to the web.
Hope you understand what I mean.
found a nice little program (flash capture) it saves the flash to a folder, the only problem is when I try to open it I am told windows need to know what program created it and wants to go on the web to find it, when I go on the web it takes me to the macromedia site and I have allready got macromedia flash player installed. I sent the captured flash to a friend and he had the same problem. Is there any program I can get that will change the format of the flash or do anything that will allow me to watch it or send it to a friend so they can watch it
Thankslife's a shit sandwich and everydays a bite
Saving/capture solutions for saving off (extending) DVR
By ET3D in forum Newbie / General discussionsReplies: 1Last Post: 28th Oct 2011, 19:13 -
Saving Vegas 9 Video-Clip in Older Format
By TKB in forum Newbie / General discussionsReplies: 3Last Post: 24th Mar 2011, 05:07 -
Saving a clip (segment) as wmv in Movica
By anon_private in forum Newbie / General discussionsReplies: 19Last Post: 26th Oct 2010, 21:16 -
Do I need to stop clip analysis in order to export clip for dvd
By maevek1 in forum MacReplies: 0Last Post: 9th Apr 2008, 09:26 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
