Hi. Amazon was selling a 100 pack of Velocity DVD-Rs that people were reporting as MCC003s. I purchased one, but it was backordered. I finally received my order and when I checked the media code it showed OPTODISCR008. I checked the media forum and there was no mention of OPTODISCR008. They only had reviews for OPTODISCR004 and Lower. Can anyone tell me if they have ever used they types of media and how the quality is? Thanks.
Results 1 to 18 of 18
Belongs in media forum. Moved...
www.nomorecoasters.com for info on media quality.Want my help? Ask here! (not via PM!)
It's +R mediaOriginally Posted by Chip718
https://www.videohelp.com/dvdmedia.php?dvdmediasearch=&dvdmediadvdridsearch=OPTODISC&ty...+or+List+Media -
I bought some of this +r media at computer fair this past weekend. 8x and complete junk! Burned at 2.4, 4 or 8x and all junk. Burning with Benq 1620 burner. Hope you have better luck as I now have some inkjet printable coasters. I could not resist buying some inkjet +r's since all I had were -r's. Junk for me...
No OPTODISCR008 is DVD-R, OPTODISCOR8 is DVD+R. From what I've read Optodisc has previously used fake TYG02 code for its 8x DVD-R but has obviously started using its own code now too.Originally Posted by disturbed1
And yes Optodisc is quite bad media. -
I would return them. OptodiscR004 is the worst media I have ever used and it can't touch MCC quality. Your burner and results may vary of course.
I have a LiteOn SOHW 812s. I'm here to tell you everyone here is correct. Don't walk away from the Opto disks...RUN from them. They are worthless. I have not been able to get a single one (that SAYS it burns at 8x) to burn anything longer than 1:30 in length, and that is at 2X. Opto disks are garbage. The most reliable 8x DVD-R media I've found are the Fuji 8X DVD-R. Here's where I finally found them:
http://www.2buystore.com/shopdisplaydetail.asp?id=E05806
I don't normally plug stuff, but after all the anguish of thinking it was my drive, my firmware, my computer... Then I tried these as recommended by another board and poof! no more problems.
BTW, they are about 52cents each with free shipping. Not bad. -
In the past Optodisc DVD-R media was fine, about same quality as Ritek. The DVD+R has always been pathetic.
Still not something I'd use on purpose.Want my help? Ask here! (not via PM!)
These are actually manufactured as plastic coasters which some genius decided to sell off as dvd media. If you actually burn anything to them successfully consider it an act of god.
We tried Optodisc and quickly moved on. The spindle started out fine, but we ended up with 20 or so coasters by the time we had finished it up ....on the Panny standalone, My Panny PC writer at the time choked on it.
I'd take it one step further and say avoid all discs unless made in Japan, USA, or Europe.
And who let Capmaster out of Off Topic anyway?
You don't see too many discs made in the USA or Europe though.Originally Posted by zzyzzx
And for your information, Cap is let loose everday from 9:00-9:15 to graze, before returning to the safe pasture of OT.
I could say the same about you and PolitickOriginally Posted by zzyzzx
Actually, the rest if the forum is much safer than OTOriginally Posted by 888888
OPTODISCOR8, 8x DVD+R, burnt at 12x in a Benq 1620. Looks pretty good to me.
I have had good results with my Benq 1620 and my NEC 3500 with the Optodisc +R.
@henry_nettles
There is no benq firmware that burns that media at 12x.
Comment on Search Function
By smartel in forum FeedbackReplies: 4Last Post: 21st Jun 2011, 05:53 -
Informed Comment
By sambat in forum FeedbackReplies: 2Last Post: 7th Oct 2009, 15:03 -
How to Edit a comment left for DVD Media
By lee220 in forum FeedbackReplies: 2Last Post: 14th May 2008, 19:20 -
Comment Regarding WM Recorder
By Seeker47 in forum Video Streaming DownloadingReplies: 0Last Post: 9th Apr 2008, 14:50 -
Comment + audio after rip
By coffeetyme in forum DVD RippingReplies: 2Last Post: 3rd Jun 2007, 17:13
