A DVD I burned recently is working fine on some players but has produced an odd effect with the audio on another.
The video and audio play smoothly and in sync but the audio volume is quiet before suddenly moving up to the actual volume for a beat or two and then quiet again. I'm told the effect is like listening to music through a faulty speaker.
I suspect this is an encoding or compatibility issue but I haven't been able to determine the cause. The content was edited as a DV AVI with a 48kHz stereo soundtrack, converted into m2v using TMPGEnc Plus (soundtrack unchanged), and then authored with DVD-Lab. So the soundtrack should be uncompressed audio, which is how I wanted it. The DVDs used are Datawrite Red V3 4.7GB -R.
Any suggestions would be appreciated.
Results 1 to 1 of 1
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 07:21 -
DVD audio volume too low
By efiste2 in forum AudioReplies: 4Last Post: 28th Mar 2012, 16:06 -
Problem -Subtitling using Subtitle Creator DVD from Multi Volume DIVX Movie
By shotokan101 in forum SubtitleReplies: 0Last Post: 4th Jan 2009, 10:43 -
DVD feature film volume problem
By m_burlock in forum Newbie / General discussionsReplies: 2Last Post: 17th Jun 2008, 13:18 -
Volume goes up and down, brightness fades in and out - DVD player problem?
By garybeck in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 25th Jun 2007, 11:37
