Results 1 to 12 of 12
  1. i have recorded several short mpeg2 clips via my dvb card.
    i tested them with gspot and virtualdubmod to determine video bitrate.
    but the resulting bitrate they show are so much different.
    gspot shows average video bitrates about 200 to 2000 kbits/s larger than virtualdubmod for same clips.
    whichone of these programs can be reliable then ?
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Hello,
    Try powerdvd or windvd. They can tell the bitrate in the configurations menu. If those match either gspot or vdubmod I'd say use the powerdvd/windvd bitrate as the "true" bitrate.
    Kevin
    EDIT - Bitrate viewer can also read mpeg files.
  3. Originally Posted by yoda313
    Hello,
    Kevin
    here are the results given by three programs for one of clips :
    gspot : 7926 kb/s
    virtualdubmod : 5166 kb/s
    windvd5 : 3917 kb/s
    Jun 2004
    Ferrara-Italia
    math I say!!
    (((file size in byte)*8/(file duration in seconds))/1000)-(audio bitrate)=
    video bitrate+overhead in kb/s (where it's assumed that k stands for 1000)
    Sorry, I had to go see about a girl
  5. For mpeg files, use bitrate viewer.
  6. Originally Posted by midnightsun
    math I say!!
    He is not trying to determine which bitrate to use as he has already encoded his clips. He is trying to determine which application he can use that will reliably identify the bitrate because he either...
    A) Forgot what bitrate he used...or
    B) Wants to be able to determine the bitrate used on other clips that he did not encode himself)
    No, I'm from Iowa. I only work in outer space.
    Jun 2004
    Ferrara-Italia
    I did understand that, thank you. If he does what I wrote in my previous post he will know what bitrate was used to encode the file, which is what he's seeking help for.
  8. Originally Posted by midnightsun
    True...my oversight. I didn't look close enough at your calculation. I just assumed your post was telling him how to calculate what bitrate to use instead of the reverse.
  9. Originally Posted by midnightsun
    math I say!!
    thanks for reply
    i did the calculation and the result was : 5039 which is near to virtualdubmod given bitrate.
    what are the other programs saying then ?
    are they pointing to max. and min. bitrate or what ?
  10. I'm a Super Moderator johns0's Avatar
    canada
    The programs will give you different bitrates cause the movie runs with with variable bitrates as its been encoded,
  11. Originally Posted by johns0
    they are not pointing to variable bitrates
    gspot is saying that it is average video bitrate :
    virtualdubmod calls it average too :
    well ....
  12. Originally Posted by koorosh
    well ....
    Gspot is simply reading the mpeg header info. Vdub is reading the whole file and calculating the real average.
