I remember a few years ago I tried two monitors and found that it dogged the entire computer. I was using a G200 and a cheapy PCI card. However, I see a lot of cards now allow for two monitors, because they have a VGA out and a DVI out. Since you can get a DVI -> VGA connector, you can hook up two monitors. Will it slow things down? Ideally I'd like to play a game on the primary monitor and have my windows desktop on the other, to monitor IM conversations, etc....
yeah there it, the videocard will perform 1/2 as well as with one monitor depending on the resolution.. if both monitors are the same.. it is also dependent on the vidoecard itself.. but for the most part there will be a hit in FPS..
Originally Posted by bazooka
It looks like it has a dvi out port on it.
You would probably have to feed the signal out to the tv. -
What program can I buy so i can make a vid like gopro hero2 vid
By DROCK71 in forum Newbie / General discussionsReplies: 5Last Post: 21st Mar 2012, 13:01 -
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 10:50 -
downloading a vid from radio-canada.com, but vid isn't available for dwld
By vivimarie in forum Newbie / General discussionsReplies: 4Last Post: 23rd Oct 2010, 11:48 -
Dynamic Resolution PC Monitors vs TV Monitors Static Resolution.
By therock003 in forum Newbie / General discussionsReplies: 24Last Post: 17th Apr 2009, 08:28 -
Vid encodes will only display first frame instead of loop at the end of vid
By SignedupGuest in forum Newbie / General discussionsReplies: 6Last Post: 8th Aug 2008, 22:09
