  1. Hello all... just downloaded version 2 and ran my first movie on it and got the following error.
    Type: System.ArgumentOutOfRangeException
    Source: mscorlib
    Message: Specified argument was out of the range of valid values.
    Parameter name: Not a valid Win32 FileTime.
    InnerException:
    StackTrace: at System.DateTime.FromFileTimeUtc(Int64 fileTime)
    at System.DateTime.FromFileTime(Int64 fileTime)
    at System.Timers.ElapsedEventArgs..ctor(Int32 low, Int32 high)
    at System.Timers.Timer.TimerAPCCallback(IntPtr data, Int32 lowValue, Int32 highValue)
    at System.Threading.WaitHandle.WaitOneNative(IntPtr waitHandle, UInt32 millisecondsTimeout, Boolean exitContext)
    at System.Threading.WaitHandle.WaitOne()
    at System.Timers.WaitableTimer.ListenerThread()
    Is this a bug or something I have done wrong or not done right?
    Thanks!!!
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Is there any more to that error?
  3. Hey C, thanks for the reply...
    Nope, that's it. Pops up a box with a "clipboard" button on the bottom of it and haults the process.
    It does it while resampling audio and adding Nav Paks. About an hour into the process.
    I'm running W98SE if it matters.
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Mmm. Can you email me the log for this please?
  5. Sure, at work on nights so I will send it first thing in the morning.
    Thanks!!!
