  1. This has happened on only two of my home videotapes. I convert using Windv, sav wav with VirtualDub, then convert to MPEG2 with TMPGEnc. In the middle of the tapes the audio cuts out; the converted MPEG just goes silent. It's been at a scene change both times, but I've not messed with the settings on my video camera. Any idea what's the problem?
  2. Lets see. Tell me if I get it right. Check all the source files for bad audio. Frameserve for bad frames in the source video.
  3. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    .............. ummmmmm ..........
    https://www.videohelp.com/glossary?F#Frameserve
    Frameserve
    The process of creating a direct video "link" from one application to another. For example a video editor application to standalone mpeg encoder so you don't need a plugin or create a temporary video file.
    Now how do you frameserve for bad frames ?
    If in doubt, Google it.
  4. Member Sillyname's Avatar
    Mar 2004
    If TMPEG is set for 2-pass VBR, there will be a significant lag at 50%.
    There's also something about increasing your DirectShow filter for TMPEG. I believe it is under the "plug-ins" tab but I am not sure. I am away from my home machine currently.
    Your miserable life is not worth the reversal of a Custer decision.
