I need advice on getting the best quality out of backing up my DVD especially the movie.
Do you recommend simply backing up the DVD and lowering the compression of everything else besides the movie ei) subpicture, unnessary audio/video
or
do you find Reauthoring the movie is better?
What is the link to Reauthoring with DVDshrink?
Do you find smooth, sharp(default), or maximum sharpness best for most movies?
Thanks so much to anyone who answers all of my questions. I appreciate it immensely.
I have been using sharp(default) for all my movies since I saw a difference in quality. It takes longer, but I can see the difference. I lower the compression on the extras only, this way the movie is not so compressed.
Hope this helps. -
I do the same thing every time:
Backup movie only in re-author keeping the 5ch, 2ch and 2ch Director Commentary and english subs. If it is too big and needs transcoding, then I use Deep Analysis and Maximum Smoothness.
Works for me!
p.s. If i want extras, i reauthor them on separate disk. -
Thank you for responding.
What is the link to reauthor using DVD shrink?
Also what noticable difference did you find mn072065 by using Sharp(default)? -
Try Alfonic's new guide for Shrink 3.2 (current version). Re-authoring is covered at the end.
http://www.dvd-guides.com/content/view/16/59/
Reauthor a DVD to play all
By burgherboy in forum Authoring (DVD)Replies: 10Last Post: 7th Jul 2011, 20:46 -
Trying to reauthor with dvd shrink
By StoneColdWhat in forum Authoring (DVD)Replies: 2Last Post: 6th Feb 2010, 17:26 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
reauthor tool for chapters
By gameroftheuk in forum Newbie / General discussionsReplies: 2Last Post: 18th Aug 2008, 04:11 -
I want to reauthor an episodic dvd
By peterhun in forum Authoring (DVD)Replies: 5Last Post: 22nd Jan 2008, 18:02
