Need Microsoft's WM Maker 2 / Real Alternative
Ok you have read other articles explaining how to convert a .rm file into something else, well there is an easier way to do this.
Install a complete install of Real Alternative (not really neccessary, but easier). Rename your movie from .rm to .avi (or I think asf will work as well) this will allow you to then import the file into Movie Maker. You can then immediately export to either WMV or AVI using File > Save. If you want a more special profile you can for Movie Maker you can create profiles that work with Movie Maker with Windows Media Encoder (X) profile creator using windows media encoder, you can find that info on the web.
This will let you export RM in WMV and DV-AVI that can then be reimported or converted into any other file type using another
tutorial here or your own active imagination.
Hope this works for you all!
Results 1 to 1 of 1
If you are the smartest person in the world, then everyone else is an idiot. If you are the opposite everyone else is a rich idiot.
3gp -> mp4/wmv audio problem
By dragonBoy in forum LinuxReplies: 1Last Post: 7th Sep 2010, 17:08 -
Golf Swing & Mpeg & AVI video Streaming
By jamesh2 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jul 2008, 08:19 -
Need a program to combine & cut divx, mpg & wmv
By sync in forum EditingReplies: 3Last Post: 14th Nov 2007, 08:02
