Is it possible to remove the cheers of a crowd from a song? What program would you use?
any audio editing program ... pretty well ..
soundforge
goldwave
wavelab
are some popular ones .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
If it's mixed in, don't expect a lot. Audience noise is a constantly changing, broad spectrum noise; much harder to remove than hum or tape hiss. Maybe try to reduce it a little to make it less annoying, but don't think you can get an audience-free recording from it.
Adobe Audition would do that job for you. It will eliminate the cheers and replace it with cool effects intro (or sometime just cut the cheer and go strait to the song...) randomly. I remember once my younger brother ripped the audio out of the live concert DVD and used this software to eliminate the background cheers (sometime it mixed w/music) and best of all, it'll do the job automatically!!!
Oh yeah, I see... I'm not sure either...
But hey... check this out in the "Automatic click/pop elimination" section
http://www.adobe.com/products/audition/pdfs/audition_nfhs.pdf
MP3 - Batch export song number/song title/etc to ID2/ID3 ?
By ralf07 in forum AudioReplies: 5Last Post: 3rd Mar 2012, 01:51 -
A time-lapse video that writes the words to a song as the song plays
By radardetector in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2011, 22:09 -
making video of song lyrics, and adding a song...how?
By snafubaby in forum Newbie / General discussionsReplies: 6Last Post: 15th Mar 2010, 03:09 -
Name of this song?
By retroborg in forum Off topicReplies: 5Last Post: 19th Jan 2010, 19:06 -
CHEERS!!!!
By pensioner in forum Newbie / General discussionsReplies: 0Last Post: 5th Jan 2009, 11:42
