Im trying to copy a 1 hour dvd(not copyrighted) to vhs. I have everything hooked up as normal for the usage of playing dvds on the tv or playing the vcr tapes on tv(which both works). However when i push record on the vcr while the dvd is playing my vcr is not recording it, i was thinking it was becuase it needs input (av input on the back of my vcr is empty) from the dvd player or the tv or that it cant do it because they are working off different video channels.
Any help in this would be great as I have cords everywhere and have became confused.
Depending on your vcr you most likely have to use your remote control and change the vcr to video 1 or 2 or aux in,if you still have the manual it will tell you where on the remote to do this.The vcr doesnt record off channels when using video in,you have to plug the cables from audio/video out from your dvd player to audio/video in on your vcr.
Actually, it doesn't matter if they work on different channels, but your output from the DVD needs to go to the input of the VCR or else you'll record nothing, as you found out.
"Rarely is the question asked: Is our children learning?"
George W Bush - Moron -
Thats what it was it needed to go to the input of the vcr. I am just tierd and couldnt think, i knew someone on here could help me. Thank you much.
You don't need to be able to see it on the TV to record it, but that's helpful to monitor the recording process.
VCR/VHS playback - lines on picture...vcr alignment problem or no?
By daysaf00 in forum Capturing and VCRReplies: 1Last Post: 23rd Jan 2012, 01:54 -
VCR to DVD
By Grandma Jacky in forum Newbie / General discussionsReplies: 13Last Post: 9th Oct 2009, 19:25 -
help to unlock my dvd/vcr
By wawabig in forum Software PlayingReplies: 2Last Post: 11th Feb 2008, 11:37 -
GoVideo DVD/VCR
By candela in forum DVD & Blu-ray RecordersReplies: 2Last Post: 10th Dec 2007, 10:05 -
Best VCR OR VCR/DVD COMBO for restoration
By demonwarrior in forum Newbie / General discussionsReplies: 7Last Post: 24th Aug 2007, 03:02
