Nero always assign Image record to Destination driver and does not allow to change to the actual driver.
Per Nero website, I ran Clean-Drives and Registry Checker utilities since I had Easy Cd Creator and maybe some incompatibility issue could happen.
What am I missing here ?
Rei
It sounds like Nero isn't recognizing your recorder. Are you sure it's installed and working properly?
if your trying to use a disc that came with another drive that's all its gonna let you do is make images
My IO Magic DVD Writer is working fine. I can watch movies using PowerDVD (Even though the image freezes).
I am using Nero Express 6 and it recognizes both drivers as Source but only assigns Image recorder to Destination. -
FYI, I've installed Sonic RecordNow only for testing purpose. It says that my DVDRW IDE 16 is "IN USE BY" and does not allow me to record. I am frustrated big time. I installed my DVDRW last week and I haven't burned a single cd...
Let me know your thoughts. -
Did you set the jumpers right, e.g. master & slave? Nero could be too old to recognize your writer, nero.com has lists of what you can use with it I suppose.
'in use' might meanyou have another program open usin g it.
Can't Find Destination File, Handbrake
By LegendaryLero in forum Newbie / General discussionsReplies: 1Last Post: 26th Jun 2011, 21:24 -
Nero 8 not recognizing DVD burner
By JCWBobC in forum Authoring (DVD)Replies: 11Last Post: 14th Dec 2009, 22:20 -
Destination file name?
By heffneil in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Oct 2009, 15:54 -
Final Destination Spoof
By hech54 in forum Off topicReplies: 4Last Post: 12th Sep 2007, 02:32 -
Destination Folder
By Gripweed in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 16th Jul 2007, 12:28
