Well I looked in that faq section on this site and I saw 2 probably causes but they both did not work. It happens right when I click start to encode, I was wondering if there is anything that people can think of on why it would be doing this ?
Maybe your Video file is corrupt, you will have to check it for bad frames and such.
Could also be bad/conflicting codecs installed. Run Showshifter (trial will do) to disable/clean up any bad codecs.
Are you overclocking your hardware? Video encoding is one of the most stressful things you can do to your CPU and memory subsystem. I had a crashing/lock-up problem with TMPGEnc when I was running near the edge overclocking my hardware. I had to back off a bit to regain stability.
The file worked before all this, I just need to reencode it so I don't think its the file
Are you sure showshifter can find confliction codecs ? If so how do I use it ?
And no I am not over clocking, everything worked fine before but now it just keeps freezing, I try reinstalling it but now it freezes every time.
VCR Freezing
By koberulz in forum Capturing and VCRReplies: 9Last Post: 24th Feb 2012, 23:40 -
Picture freezing
By Toes01 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 5th Jan 2012, 15:52 -
Tmpgenc keeps freezing
By WinSpecToR in forum Video ConversionReplies: 6Last Post: 12th May 2008, 01:08 -
Why are my movies freezing?
By bigmatt72401 in forum DVD RippingReplies: 10Last Post: 6th Aug 2007, 06:41 -
TMPGENC DVDAuthor 3 freezing up during output process
By CodySave in forum Authoring (DVD)Replies: 1Last Post: 21st Jul 2007, 12:57
