I got this 960x528 xvid avi file, it has ac3 audio included, I would like to get this file in a format which works for DVD so I can burn it on one and play it at a standalone dvd player.
Now I've alrdy tried almost all guides on this site, but I just can't seem to get it as sharp as the original. I think its because no program allows me to convert without altering the resolution...but I dunno for sure, anyone has a suggestion ?
As you're going to watch it on TV, I don't think you're going to see any difference, provided you can use enough high bitrate. You might see some loss i detail on a monitor, but then, there's no need to do a DVD if you're going to watch it on the computer...
To be authored as DVD, it has to be resized to 720*480 (NTSC). I use Lanzcos resize filter (VirtualDub/AviSynth) which I think gives the best result.
/Mats -
Hello,
Originally Posted by mats
Maybe it was Pal to begin with,and in that case it's a different frame rate, and thats why it works out for you.
AVI bitrate (regardless of codec) and mpeg bitrate is totally unrelated. What do you use to encode to DVD mpeg?
/Mats -
I've been using TMPTEnc Plus 2.5 sofar
I dont want or need anything fancy, just a decent conversion. One where I can't see the choppy sides of straight lines in the movie, just like in the avi file. It has briliant, clear and vibrant colors very nice sharp edges...exactly the kind of stuff you want on a dvd..
As for the NTSC - PAL stuff...I really don't care eitherway, think it will both play anyways.
Please help. Problem Converting CCTV DVR mpg file to dvd format with audio
By sinisterzane in forum Video ConversionReplies: 4Last Post: 16th Jun 2011, 18:28 -
Help Converting an ISO Image File into a DVD Format playable on DVD players
By Gradyj in forum Newbie / General discussionsReplies: 5Last Post: 19th May 2010, 20:13 -
Converting EF File Format in to Video Files
By Teac23 in forum Video ConversionReplies: 3Last Post: 23rd Jan 2010, 13:13 -
Converting MKV file to DVD burnable format
By ryoden in forum Video ConversionReplies: 6Last Post: 29th Jul 2008, 13:54 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 08:21
