If I convert my DV-NTSC file to an mpeg2 format (is that both video DVD and CD-ROM DVD?) and then burn it onto a CD-R and then play it in a DVD player?
You can author a xvcd or xsvcd with your mpeg2 files and burn it on a CD-R. If you make a miniDVD (DVD on CD-R) it can be used in a PC but not in all standalone DVD players.
You don't have to scale to the correct size, just use the original size of the movie. 720x480 or 720x576. If you convert the audio from 48 to 44.1 is much better.
I'm testing all the possibilities in a Philips 612 and it playes what ever I put in it.
Under "Author" is some guides.
How to import MPEG2-TS to Adobe Premier? How to convert MPEG2-TS to MKV? :)
By farzad in forum EditingReplies: 19Last Post: 29th Feb 2012, 16:25 -
mpeg2 ts file convert to mkv or mpeg2 ts......change only video bitrate...
By jrblack in forum Video ConversionReplies: 4Last Post: 24th Jan 2011, 18:45 -
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 14:18 -
Super, mpeg2 16:9 to mpeg2 4:3 letterbox
By JN in forum Video ConversionReplies: 4Last Post: 10th Dec 2009, 02:35 -
Simple question: how to compress 4GB mpeg2 to 1GB mpeg2
By jimdagys in forum Newbie / General discussionsReplies: 29Last Post: 3rd Jan 2008, 08:45
