Results 1 to 14 of 14
  1. Here's my problem. I've been playing around with my new Philips DVD recorder, and editing using my PC and TMPGenc XPRESS 3. However, when I delete various titles on the DVD recorder, the PC still sees SOME of these files, and the whole editing process becomes impossible, probably because of the different file systems used. When I format the RW+ disc in NERO (Full format), the disc is then unreadable in the DVD recorder (It says'Invalid disk format'). I can of course use a new RW disc, but of course if I'm only going to be able to edit properly after the 1st burn, I might as well use a non-writable disc. The DVD SETUP menu for formatting (Though it's not a proper full format, just marking free space for the recorder, and thus the cause of my problem) is not accessible after I format a disc in NERO. Is there any way to format a RW+ disc so that my DVD recorder will accept it as it would a new disc? Thanks
  2. You want to "erase"not format..?
  3. Is this not the same thing? If so, how do I ERASE the disc?
  4. I think nero has a button "Erase" to click. I know record now does..
  5. Obviously 'Erasing' the disc does not produce blank data as a new disc, because the DVD recorder won't accept it.
  6. What?? Obviously To record onto the disc it must be empty...Erased.
  7. Hey up, I've just formatted using EASY MEDIA CREATOR 7, and it works fine. Don't ask me why.
  8. Great!
  9. Try putting the disc in the recorder tray, but do not hit the button to close the tray. Hit "record" on the front panel or remote. The tray should close and either recording will start or you will get a screen that asks if you want to record over the disc.
    Dec 2004
    Indiana-USA
    When i do a quick erase using NERO and then try to record that disc in my Philips DVDR75 it tells me that the disc contains unknown data and then tells me if I want to erase it to hit record.
    Has worked every time so far.
  11. I formatted a dvdrw once, took 40 minutes....
    I prefer dvdram, these take me about 30 sec to format.
    Feb 2002
    Bull's eye - NY, ny usa
    Copy a VR-formated-blank to your RW.
    OR you can:
    Save to HD all the folders of a formated only VR disk
    ISO or bin or image burn them.
    ignore all error mesages
    see:
    https://www.videohelp.com/forum/viewtopic.php?t=246174&highlight=
  13. Originally Posted by RonBoy
    I've found the same. Just press 'record' on the remote. I should add though that when using a RW disk, the erase funtion doesn't work properly on the Philips recorder. The old movie still breaks through at some points. However, erasing the RW on my computer using Nero, works fine.
  14. Member Cornucopia's Avatar
    Or you could try not using the "Quick Erase" feature, but rather the "Full Erase".
