  1. Ever since I upgraded my graphics card to a GForce 5200 128mb with Tv-out, every time I try to play a copy protected DVD (i.e macrovision) with PowerDVD, it displays the error message 'The TV-Out on your graphics card is not working properly' and starts complaining about protected discs but the tv-out is working perfectly. What the hell is going on?
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    In the NV control panel, go to performance setting and select the 'global driver settings'
    You then need to switch advanced options on.
    Scroll down the list of settings and you should find a setting like 'single display mode', tick that checkbox and hit 'ok' - This will disble the TV-Out port in the drivers and hence should solve the problem
    Google is your Friend
