I am looking for a software by which i can extract 6 CHannel Audio in file. I have a DVD and i want its Center Channel audio. And I think if i extract 6 channel audio in a file (Which can be in any format but shows 6 channel in any editing software) and I can choose any channel for my need. Please let me know if there is any software to do it.
If the audio is 5.1 AC3, you can simply load the VOBs in ReJig and demux the AC3 track. From there, to decode/extract just the center channel, I'm lost!
/Mats -
If it's an Ac3 file then use:-
1.ReJig (ifo mode) to demux the vob files directly from the DVD.
2.Avisynth (using a combination of 'Directshowsource' and 'getchannel')
3.Framserve the resultant avs file from above to Virtualdub and 'save wav'
You then have a single channel wav file.
There are probably other and quicker ways of doing it but this way is FREE -
Can you please tell me the easiest way. I am not an expert user. I have copied VOB files on HDD and from there i want to extract all the 6 channels in different wav files.
delaycut - ac3/eac3/dts/mpa/wav delay+cut tool: v1.4.3.2
By amtm in forum AudioReplies: 21Last Post: 23rd Nov 2011, 09:34 -
mkv with ac3 audio -> avi with ac3 audio ? is this possible?
By Substance001 in forum Video ConversionReplies: 9Last Post: 21st Jun 2011, 00:56 -
A Tool for editing AC3 without recompress? (like mp3DirectCut)
By CactusMan in forum Newbie / General discussionsReplies: 0Last Post: 27th Mar 2010, 14:28 -
oneclick tool to convert avi with 2 audio tracks to episodic DVD with menu
By ajamarkova in forum Video ConversionReplies: 3Last Post: 12th Mar 2008, 21:50 -
Tool to fix audio pitch problem from DVD?
By haymes in forum EditingReplies: 0Last Post: 29th Nov 2007, 18:15
