Hello all,
I have a task to compress 3 minutes of dv as small as possible to upload to my site. The main thing is not to lose much quality because the scene happens at early evening otherwise it won’t be recognized. I converted to wmv using 1500kbps, the quality was good but 45 MB is a lot and will consume much bandwidth on my site. I wonder which codec is the best to encode 3 mins to less than 10 Mb keeping high resolution .
Thanks for any help.
Try working backwards:
3 min. = 180 seconds, 10 MBytes = 80 Mbits
Target bitrate <= 80 / 180 = .444 Mb/sec
Now, what codecs give high quality and high resolution at that bitrate? NONE.
Now you must decide where to compromise...
My suggestions:
1. DeInterlace and resize to 1/2 or 1/4 resolution (e.g. 720x480 NTSC DV --> 320x240)
2. Drop Framerate in 1/2 (e.g. 30/29.97 fps NTSC --> 15 fps)
3. Constrain color space (e.g. 24bit --> ~16bit), but don't dither.
4. Use advanced codecs (e.g. Sorenson3 or MPEG4 for Quicktime, Real9 for Realsystem, WMV9 for WindowsMedia, DivX5 etc for AVI)
5. If at all possible, ENCODE in 2pass VBR!--make target = avg. bitrate
6. Minimize (or drop completely) the bitrate requirements for audio
7. Judicious use of DNR/Blur/USM and Contrast/Gamma correction
Using a combination of the above, it's quite possible to get decent (subjectively) video through your available bandwidth.
HTH,
Smallest FLV output
By curt3006 in forum Video Streaming DownloadingReplies: 5Last Post: 26th May 2011, 12:54 -
best quality smallest size
By Reckitt in forum Video ConversionReplies: 2Last Post: 27th Feb 2011, 09:39 -
smallest file possible in DVD quality
By spiked4life in forum DVD RippingReplies: 6Last Post: 24th Feb 2009, 09:57 -
AVI to MPEG smallest bitrate?
By michcio in forum Video ConversionReplies: 11Last Post: 29th Aug 2008, 20:09 -
Best (smallest) format for movie burning
By Choppa in forum Authoring (VCD/SVCD)Replies: 30Last Post: 1st Oct 2007, 10:38
