Ok, the problem looks/sounds like this:
I try to mark a starting frame at a place where the videoclip fades in and fades out at the same place, meaning when you use "shift" for moving it's not a 'jump' frame. (Sorry for my bad English, can't put it in other words..)
I mark the ending frame and save the new file, but when i check it it starts at different point - the 'jump' frame before the place i marked...
I noticed it's not an issue with ending frame, you can put it wherever you want, but fot my starting frame it has to be the 'jump' frame.
Is there some sort of option in Vdub for fixing this that i can't find? This might sound like a newbie question, but plz help me...
If you're using "direct stream copy" for the video you can only start the video on what you call a "shift" frame. In reality it's called a key frame. If you want to start a cut on a non key frame you have to use full processing. I'm not sure if it will work for the other processing types.
Thanks for the reply man.. Goddamit this is sad that nothing else can be done about it.
Virtualdub and cutting precisely
By silverwolf0 in forum Newbie / General discussionsReplies: 16Last Post: 2nd Jun 2023, 06:39 -
How to open a small flv file in virtualdub?
By Wizard81 in forum EditingReplies: 4Last Post: 20th Nov 2009, 13:14 -
vdub virtualdub can I combine several small avi files into one
By case310350 in forum EditingReplies: 2Last Post: 5th Jan 2009, 03:23 -
problem with cutting AVI in half with VirtualDub.
By eroy in forum EditingReplies: 1Last Post: 27th Dec 2007, 07:53 -
Is there not something better than virtualdub for divx cutting?
By pondleaping in forum EditingReplies: 23Last Post: 5th Jun 2007, 12:45
