I burnt a DVD with 60 video clips on it, one after another, with a number in the bottom left corner that changed each time the video changed. When I play the DVD on my computer's DVD player, it looks fine and I can see the numbers, but when I play it on a TV's DVD player (I tried three different ones) the bottom part of the videos are cut off, and you can't see the number. Does anyone have any idea why this might be? Any help would be greatly apprecciated.
What did you use to burn the files ?
Most editors, and many DVD authoring packages, have a feature called Safe Areas. Turn this on, and anything falling outside the Action Safe area probably won't be seen on most TVs. Inside the Title Safe area will almost always be seen.
If you want your numbers to be visible, put them inside the Title Safe area, or resize your clips and put a black border around them.Read my blog here.
I burnt the files using Nero. I didn't see an option for safe areas but I'll check again, thanks.
Samsung DVD P230 player gets confused
By ckmoore in forum DVD & Blu-ray PlayersReplies: 0Last Post: 22nd Mar 2012, 19:11 -
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 11:26 -
Change of Region Code incorrectly set on DVD player
By cashey007 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 12th Mar 2010, 21:12 -
confused, dvd player with mpeg4, does it means it can play mp4?
By c1steady in forum Newbie / General discussionsReplies: 6Last Post: 4th Dec 2009, 10:00 -
Error Reading by GOM and Media Player Classic in reading MKV video
By cutefix in forum Software PlayingReplies: 1Last Post: 31st Mar 2009, 00:25
